What the hell?
I've got Continental Extreme Contact DW's
On the front - 245/40ZR18
On the rear - 275/35ZR18
Now what confused me is, from what i understand when looking at this.
It seems like my front tires are taller than my rears, the only other thing I could come up with is the tire height number correlates with the width so /40, would not be the same height for all widths...
Can someone help me out...
Rear - 25.6" diameter
The difference is 3.5mm. It's all in your head.
http://www.miata.net/garage/tirecalc.html
tire width/tire profile (this number is percentage of width)/ rim diameter
above explains the tire sizing numbers.
To get overall diameter, convert the mm to inches, multiply by 2 and add the rim diameter (18).
245 = tire width measured in mm
40 = aspect ratio or sidewall size
18 = rim size measured in inches
To find the diameter of the tire, you take the aspect ratio as a percentage of the tire width. In this case, the aspect ratio would be 98mm (245 x .4). If we add it all together, we get the overall diameter of the tire.
Wheel size = 18" or 457.2mm
Aspect ratio = 98mm (x2 since there is a sidewall above and below the rim)
Overall diameter = 653.2mm or 25.7"
(1" = 25.4mm)
Your rear tire would be....
Aspect ratio = 96.25mm (x2 since there is a sidewall above and below the rim)
Overall diameter = 649.7mm or 25.6"
But
Is anyone else positive that I won't get rubbing with these tire sizes if I am only lowering with through star??
I can't speak for your wheel offsets and widths, though.
