275 or 285 with 19x9.5 et40
11'GTR,08 Jeep 426 SRT 8,06 E55
I am trying to decide between these two sizes of Conti Extreme contact DW (not dws)
245/35-19 and 275/30-19
or
255/35-19 and 285/30-19
the rim specs are
19x8.5 ET35
19x9.5 ET40
I will be using these rims.
https://mbworld.org/forums/w211-amg/...gain-ever.html
My car is not lowered but I may consider a slight drop in the future but nothing slammed. I would prefer to have a little more sidewall for ride and rim protection but I am not willing to deal with any rubbing.
thanks for any input
John
06' E55
or
the rim specs are
19x8.5 ET35
19x9.5 ET40
John
06' E55
If the rear offset is any less than ET38 it will rub with 285/30/19 on a 9.5 and 10"wheel with a lowered suspension
If this quote is true I should be fine ??
my 19x10 forgestar f14's with et35 works with 285/30/19 on my lowered e55. i also ran the same tire on a 19x10 et40 rim with zero problems.
Id go with the 275.. Your not going to gain much sidewall going from a 275 to 285 anyway, so you mine as well stay safe with the 275 then you definitely wont rub..
I am leaning toward the 275 like you mentioned. I thought the sidewall was pulled in more on the 245/275 but it really looks about right now that I have taken a closer look at the car with the factory wheels.
thanks for your replies.
