What's this engine noise? VIDEO
Old May 9, 2011 | 09:15 PM
benz_addict's Avatar
V12TT
http://www.youtube.com/watch?v=HD1ZPtzueaE
coming from drivers side bank
Old May 9, 2011 | 10:11 PM
AWOL's Avatar
e55
check to make sure a plug wire didnt pop off
edit: sounds more mechanical, i got nothing
Old May 9, 2011 | 10:51 PM
GT-ER's Avatar
2005 E55 AMG
I'm pretty darn sure it's valve spring related. Seems like you maybe broke a lifter or something. That valve cover should come off ASAP before you cause more damage!
I think I have a lifter that's on it's way out too...it's kinda noisy but not nearly as loud as yours.
Old May 9, 2011 | 11:11 PM
O-55's Avatar
2005 E55, 2009 VW GLI
may be a bad wrist pin as well. try pulling plug wires off one cylinder at a time and see if the knock lessens or goes away. have you tried pulling your oil cap off while the car is running to see how much blow by you're getting?
Old May 9, 2011 | 11:15 PM
GT-ER's Avatar
2005 E55 AMG
No way....it's WAY too loud ( superficial ). Unless his piston is half gone, a damaged wrist pin wouldn't sound so loud. Plus, a lifter is FAR more likely to be at fault ( in cars in general, don't know about the 55K in specific ).
Old May 9, 2011 | 11:27 PM
kustom2k1's Avatar
03SL55
Sounds mechanical, I would not rev the motor, head needs to pulled or valve cover. There are actuators (like rocker arms) one may have loosened. Hopefully.
Old May 9, 2011 | 11:29 PM
O-55's Avatar
perhaps, but i was only suggesting other avenues to pursue to help him figure out his issue. it may be lifter related, but you can't rule anything out.
Old May 10, 2011 | 12:26 AM
GT-ER's Avatar
2005 E55 AMG
Definitely. I guess removing the valve cover would be the easiest thing to do.
Old May 10, 2011 | 01:53 AM
V12TT
Thanks for the response guys. It's loudest at the # 5 cyl area. I took the cover off and saw that the exhaust valve SPRING has been rotated and does not light up with the paint on the lifter and spring. All others seem to be in line but I will see tomorrow.
BTW yes there is a quite a bit of crank case pressure as I had made a new thread few weeks ago asking about my oil dip stick popping out.
All the lifters look solid and feel good how do I tell if one is bad? Stretch marks?
I will take detailed pictures and post tomorrow.
*edit* could it be possible #5 exhaust valve is not lifting properly therefore causing back pressure into the crank case (though the rings) and making excessive pressure?
Old May 10, 2011 | 07:29 AM
GT-ER's Avatar
2005 E55 AMG
Nope...a leakdown and compression test is your next best bet.
Old May 10, 2011 | 07:58 AM
MRAMG1's Avatar
S600, GL450, GLC 43
What about an exhaust leak. Do you have headers on her or stock manifolds?
If its headers, could be as simple as a bad gasket.
In either case, a compression check is your next BEST test. They only cost about $30 at any auto part store.
A vacume gauge would also tell you VERY quickly if it is a lifter or spring.
That would be my next test for you.
Good luck
Old May 10, 2011 | 11:09 PM
V12TT
Good luck
could be
I'm getting the car diagnosed from the stealer
Thanks for all the help guys ! Appreciate it!
Old May 10, 2011 | 11:27 PM
alltrac's Avatar
2004 E55
Good luck
thats way far from an exhaust leak....
Old May 11, 2011 | 06:31 AM
MRAMG1's Avatar
S600, GL450, GLC 43
Depends my friend
But it does sound like it is only coming from 1 cylinder.
Old May 11, 2011 | 12:18 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Here's hoping it's something simple for ya bro.
Keeping fingers crossed for valve retainer or somethin
Old May 11, 2011 | 03:12 PM
Evolved8's Avatar
AMG Fam
Any updates bro?
Old May 12, 2011 | 10:45 AM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
This after having just replaced its rod bearings? Damn.
Good luck with it.
Old May 12, 2011 | 10:56 AM
nicco's Avatar
E55 AMG
any updates??
Old May 12, 2011 | 11:54 AM
GT-ER's Avatar
2005 E55 AMG
Good luck with it.
Holy crap, I forgot it's the same user. Ouch.
Old May 12, 2011 | 12:19 PM
MRAMG1's Avatar
S600, GL450, GLC 43
Good luck with it.
Well, that opens up a whole big can of worms
Good luck OP
Old May 12, 2011 | 01:22 PM
Jakpro1's Avatar
No news in Benz world is not usually good news.
I gotta bad feeling in my crank about this.
Any updates?
