Install secondary Heatexchanger
E55 AMG W211 - sold, CLS 500 C219, E63S AMG W212
Hi guys,
i need your help to install an secondary HE.
I bought the he by froozenboost.
Actually i drive an 172mm pulley.
My question:
- I also need another i/c-pump. Should i take the meziere w136?
- Should i split the i/c curcuit ?
- Should i also add an water reservoir?
- Is something else needed?
Thank you
My question:
Thank you
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
- meziere
- if you want to
- with the split circuit you will need a reservoir as a fill point
- need to read the DIY this info is posted numerous times
- if you want to
Thx shardul :-)
Is there more benefit by splitting the curcuit ?
I'll need an small reservoir by splitting but some add an big water reservoir also, i have seen.
When you split the system, would it be overkill if you had a 4-5 gal rear reservoir which flows through a wp136 through a secondary heat to the intercooler and back to the rear reservoir?
E55 AMG, 72' Toyota Carina, 63' Ford F100, 72' Mercedes 250c, 15' Harley Davidson Softail
it would be overkill for his 172mm pulley as shardul stated, benefits of a rear reservoir would be beneficial for those running a larger pulley because of heat soak issues.
are you talking about the WP136S? if so it should be fine although I believe you have to mod the bracket to mount it correctly.
