Help, car bogs down after few runs. (new pump/he) air in system?
Old 05-29-2011, 08:10 PM
tbal's Avatar
Haters crazy
Angry Help, car bogs down after few runs. (new pump/he) air in system?
Alright boys I'm in a bit of a puzzzle...
Last week I did a new HE and new Bosch pump, new coolant...
Today was a fairly warm and nice day, so decided to go for a drive. After 5-6 WOT pulls, the car bogs down (SC inactive), but as soon as I turn the car off than on, or give it a few mins, the car runs fine!! First instinct would be pump is dying... correct? Not the case because its brand new, and I've had it hooked up for 2-3 15-20min sessions to bleed the air from the system...
I'm waiting for the car to cool down so I can bleed the system again. Could air in the system cause such a problem? Could it be the pump, regardless it works when wired directly?
I don't know if this is relevant but I've smelled oil on a few occasions as well. (Could a leak in the system, eg. surge tank gasket cause an issue like this?)
Any thoughts?
Old 05-29-2011, 08:40 PM
ahmad0658's Avatar
Brabus K8 E55 05
I would like to see the feedback you will get for your issue. Have noticed while you are driving 90 - 100 MPH that the car goes like it changed a gear or as if the TB changed position suddenly ??!!! I have this issue since a while and I got CELL too sometimes. Also, when I get this status, the car loss power and when I drive 10 - 20 MPH I can feel hesitating and bogs. Also, sometimes like the car will shut down but it automatically regain stabilization in rpm. I used to have this sometimes even with the Mezerie pump.
Old 05-29-2011, 09:09 PM
tbal's Avatar
Haters crazy
Looks like still air in the system!!? Wtf
http://www.youtube.com/watch?v=aNxjU...e_gdata_player
Old 05-29-2011, 10:27 PM
skratch77's Avatar
2005 E55
You should invest in a scan tool that shows intake air temps.
PS even a stock car will shut down if you do 6 wot runs back to back in the summer heat
Old 05-29-2011, 10:30 PM
Roverron's Avatar
ML63
Do you have hoses hook up correctly into pump and H/E?
Old 05-29-2011, 10:31 PM
tbal's Avatar
Haters crazy
Really? lol
Bled system for a good 30mins, fluid was clear no bubbles what so ever... Could a leak in the system cause a hiccup like this? But once I turn the car off, than back on, I can do another few pulls...?
Old 05-29-2011, 10:33 PM
tbal's Avatar
Haters crazy
OH SNAP! Never thought about that! LOL
The outlet hose from the Pump should goto the bottom of the HE or top npt?
Old 05-29-2011, 10:37 PM
outrun's Avatar
2004 E55
ruh roh. Interested to see if you have it right just to save me the hassle of making this same thread if I ever have to do this...
Old 05-29-2011, 10:39 PM
tbal's Avatar
Haters crazy
LOL, I will ban myself if indeed I have them backwards. lol
Old 05-29-2011, 10:40 PM
viper04's Avatar
tbal
Do you know your IAT? when this happen? That would answer some of your questions. If you don't want to go all out on a log tool,. Just get a Innova 3130 you can log a few things, IAT's being one of them. At least you would know if your pump change made a differences and if your IAT's are high.
Old 05-29-2011, 10:48 PM
tbal's Avatar
Haters crazy
Dont know IATs looking at some obd scan tools...
Reason I did the HE and pump upgrade was because my IAT's were high as I noticed on the dyno...
Old 05-29-2011, 11:09 PM
KLR CLS's Avatar
CLS63 PP
Air in the system could certainly lock the flow. Like everyone else said, only way to be sure is the Scan tool
Old 05-30-2011, 01:24 AM
tbal's Avatar
Haters crazy
Does anyone know the fuse/relay for the IC pump?
According to Alldata, its Relay A, in the trunk (Very bottom). I thought it was a fuse? Can anyone confirm.
I get the feeling their is no power going to the pump, until I get a datalogger to check IAT, going to wire the pump to run all the time and see if that makes a difference. Apparently 03 e55's ic pump ran all the time, but because of quicker failure of the pumps, they were later switched to only come on when sc engages?
Old 05-30-2011, 02:51 AM
sneakyneon's Avatar
Bicycle
You had to know this was coming....
You need logging software of some kind.
Ive said many times before, You can never fix a problem if you don't what its doing.
First mod should be a least a basic odb scan tool.
http://www.scantool.net/
Old 05-30-2011, 03:04 AM
tbal's Avatar
Haters crazy
LOL... I know I know, I'm being cheap! Thanks for the link will grab that one, was looking at same one earlier...
Old 05-30-2011, 09:27 AM
keith954's Avatar
cls55
Which one would you get? I don't want to get one that has features I would never use, but don't want to get one that doesn't have all the features I could have used.
Old 05-30-2011, 11:23 AM
AMG_RL's Avatar
E55 AMG, 72' Toyota Carina, 63' Ford F100, 72' Mercedes 250c, 15' Harley Davidson Softail
have you checked your tire pressure?
Old 05-30-2011, 11:28 AM
AMG_RL's Avatar
all kidding aside I'd re-check all the lines and bleed the system one more time before throwing money on a scan tool.
Old 05-30-2011, 01:32 PM
E55Dimon's Avatar
E63S
The BS just doesnt end for ya T.
Old 05-30-2011, 01:34 PM
tbal's Avatar
Haters crazy
LOL if you didn't post this I was about to go check the tires ahaha I've heard these cars are finicky with tire pressures.
Double checked the lines, no leakage, system bled to death with noooo bubbles.
Could the relay/fuse for ic pump be dead? Anyone know locations?
Also did I hookup my HE lines correct? Anyone have a picture the car share? Or tell me if the line(hose) out from the ic pump goes to the top npt or bottom npt of the heat exchanger?
Old 05-30-2011, 01:36 PM
tbal's Avatar
Haters crazy
Tell me about it bro the way things are going I might just dump the 55 for a m5 lmao ahaha
Old 05-30-2011, 01:37 PM
tbal's Avatar
Haters crazy
Just got the basic compact one it's 50$ shipped on eBay should be good for basic ****
Old 05-30-2011, 01:42 PM
tbal's Avatar
Haters crazy
So just got off phone with well known Benz speciality shop locally about the problem... Both said sounds like a charge pump issue? Ic pump? Lol
Old 05-30-2011, 01:54 PM
skratch77's Avatar
2005 E55
Okay you think you have a bad pump but you have no idea what your intake temps are.IM going to be the first one to welcome you to the 180mm pulley and summer weather inferno you have blowing volcanic air into your engine.
If its 90 out and your running a 180 pulley your car is going to shut down after 6 wot runs.My car is at 105-110 right now off boost!I havnt even engaged the s/c yet.
Old 05-30-2011, 02:01 PM
tbal's Avatar
Haters crazy
Until I get the scan tool delivered yes I wont know the IATs. But pump is working because I had the sob hooked up for 1 good hour last night lol...
Doesn't get that hot here... when I was doing the pulls it was about 16-degrees Celsius so around 62ish Fahrenheit?
Peak of summer it hits 86 tops if that. Welcome to Vancouver haha.
Quick Reply: Help, car bogs down after few runs. (new pump/he) air in system?
