Cracked Evosport Header - Now What?
Old 06-04-2011, 05:56 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Originally Posted by brad @ evosport
There is a reason we use mild steal.
Freudian slip there?
Kidding, kidding... couldn't resist a lay-up like that.
Old 06-04-2011, 05:58 PM
TheVazha's Avatar
W212 E63
Originally Posted by komp55
No, haven't contacted him yet since I don't see how I meet his second requirement...I bought mine used, albeit barely used, but not from a dealer and not directly from Evosport...
I would hit him up anyway. I dont think it matters who you bought the product from, they warranty the part, not the name on the receipt. Even if they can just weld it for you I think that's better then nothing...
Old 06-04-2011, 06:51 PM
PREMIER SPONSOR
brad @ evosport's Avatar
None fast enough!
LOL, nice one! Corrected!
Yes, I would contact him too!
Brad
Old 06-05-2011, 08:58 PM
komp55's Avatar
ML550
PM sent.
Old 06-06-2011, 03:03 PM
nick 55's Avatar
GL550, C55, 335i Coupe, vintage Mustang
I definitely think you should replace the motor mounts. I went through this with a customer last summer, and his mounts were not leaking or cracked, just collapsed. Over the winter, I had another customer with stock manifolds break at the collector because he had bad mounts. His were leaking and when I took them out, the passenger side upper portion had completely separated from the lower portion.
Also, at the same time, you might look at the SLK55 transmission mount, because it is a solid rubber design versus the crappy OEM mount used on every other model MB out there.
Nick
Old 06-06-2011, 06:26 PM
komp55's Avatar
ML550
I already posted above I'm going to do a refresh of the mounts (even though the dealer states they're okay). So I think the SLK55 mount you're referring to is part no. 212 240 04 18. Is that the correct number? Thanks.
Old 06-12-2011, 12:18 PM
  #32
komp55's Avatar
ML550
Update:
I've been in contact with Evosport and will be sending them the headers for repair.
Did the surgery and reinstalled new mounts and the factory logs. The driver side header was not cracked. The passenger side header had a crack extending about 2/3 around the entire pipe:
Top view:
Bottom view:
Old 06-12-2011, 01:22 PM
  #33
AWOL's Avatar
e55
wow
Old 06-12-2011, 01:30 PM
  #34
novae500's Avatar
W211
damn, was the result due to worn motor mounts? i came close to buying these from another member on here.
Old 06-12-2011, 01:48 PM
  #35
komp55's Avatar
ML550
My MB dealer, who discovered the crack during a routine Service "A", inspected the motor mounts at the time and said they were fine. I've replaced the mounts now, anyway, as a precautionary measure.
Old 06-13-2011, 04:20 PM
  #36
PREMIER SPONSOR
None fast enough!
That definitely looks like a motor mount issue. Glad to hear you replaced them!
Let me know when the headers are inbound to us.
thanks
brad
Old 06-13-2011, 07:20 PM
  #37
sparky909's Avatar
2006 E55 Pewter - Stockish
Sorry for the ignorant question - So an E55 can use solid rubber SLK55 transmission mounts to replace the fluid filled motor mounts? I just want to clarify that for the future when mine need swapping...thx
Quick Reply: Cracked Evosport Header - Now What?
