Old Jun 10, 2015, 12:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Exterior Guides
Print Wikipost
Rolling down the windows with the key?
Old Jul 31, 2011 | 01:38 PM
spazmoid's Avatar
2018 E63s, 2004 E55 AMG
Originally Posted by Meeyatch1
I got this to work ONE TIME, and now nothing! Argh!
!! Got ya beat. I got mine to work twice and then nothing!
Old Jul 31, 2011 | 11:03 PM
izzyz28's Avatar
2004 E55 AMG
I just tried mine again(at 10 PM) with my main remote that I use everyday, and it worked great from about six feet away. However, it absolutely will not work during the day. I've tried multiple times in the last week and nothing. I will replace the batteries in the remote and try again. If it still doesn't work, then I give up. Sadly this is probably the only cool feature the car has that I actually want to use.
Old Jul 31, 2011 | 11:11 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
The key fob operates on an IR (infrared) signal. The IR signal is affected by sunlight which explains why it worked at night but not during the day. Try parking in the shade if possible and that should help.
Old Mar 21, 2012 | 12:41 PM
jnash's Avatar
2017 S63
For those of you who have the infrared sensor in your door handles, this should work. However, the sensor is prone to fail with bad solder joints due to door slamming. You can either replace the part within the door handle assembly or repair it. I very carefully dug out the potting material on the sensor part where the infrared component points outwards and re soldered the bad joints, and then re potted. They are easy to remove from the door. On the back edge of the door level with the door handle should be a rubber plug. Behind here is one screw that holds the infra-red assembly part in place. Unplug the cable, and pull out the sensor from the outside, and replace or repair. Be careful not to drop the screw down into the door. Mine has a plastic catch to hold the screw when its unscrewed, yours may not.
Good luck.
Old Mar 21, 2012 | 03:10 PM
alextaylor29's Avatar
2004 E55 AMG
I DON'T have keyless go and can do this with my key FOB. I have an '04 E55 and it works both to roll the windows (and sunroof) down and up as well.
Super handy for the hot AZ weather.
Alex
Old Mar 21, 2012 | 05:04 PM
JOSHE55's Avatar
2006 E55 AMG
my 06 e55 used to do this but now it doesnt work, and i just recently changed the battery in my Key FOB. any one have any ideas as to what the problem is? it wont open or close when i hold down the lock/unclock button and having it pointed at the driver side door
Old Mar 25, 2012 | 10:15 PM
  #32
1911jon's Avatar
04 E55
I just tried this. I had no luck with the FOB method, but the keyless go door handle button sequence did work...and was very cool.
Great thread, thanks for the info.
Old Feb 18, 2013 | 11:53 AM
  #33
KHARBAT1's Avatar
2002 MERCEDES BENZ C320
EXPIRED ?????
Old Feb 18, 2013 | 11:58 AM
  #34
KHARBAT1's Avatar
This feature works 50% of the year , must be tempreture related " Summer convenience " , any one knows if this is not True ? How can we verify that this window/sunroof openning feature ( using the fob key) doesnot depend on the temreture inside the car ??
This is my experience with it , I wish that the design Engineer would respond, hahahhah
Why else would they call it " SUMMER CONVENIENCE " ?
Old Feb 18, 2013 | 03:23 PM
  #35
forcefed4door's Avatar
05 E55, 06 Audi S4
It's pretty obvious after reading this thread that the ir on the door handle goes bad... Hence why its hit or miss... On my 05 e55 the feature does not work... Maybe ill pull it apart one of these days.
Old Jul 4, 2015 | 02:17 PM
  #36
IMIEIW's Avatar
Veteran: Air Force
E550
Well at least I'm not the only one. It does work 1 out of 20 times on my 2008 E550 but I just don't understand that on my 2001 E320 it always worked, everytime. I guess as time goes by they find a way to make these sensors cheaper and less hardy. I've also tried the trick with the handle and it doesn't work for me. Oh well
Old Jul 7, 2015 | 11:49 AM
  #37
Denroll's Avatar
'06 E55
I managed to get this to work once. It's pretty frustrating. My DD is a Ford Fusion and I can get the windows to roll down from a few hundred feet away.
Old Nov 27, 2015 | 01:01 AM
  #38
kellyr1's Avatar
C-300
Thumbs up Shield the door handle IR sensor
Here's something to consider. Both of my remotes work fantastic at night(worked from the back of the car), but during the day it's hit or miss. One of them wouldn't roll down the windows this morning even with an overcast sky, my hand shielding the sensor, and the remote 2" away from the sensor. The best thing you can do is get fresh batteries and say a prayer.
My CLK320 Summer opener works great at night, but never in daylight. Then once I smothered the door handle with my body to make the IR sensor see darkness and squeezed the fob between me and the door handle. Poof, it worked, and now it does every time I use that strange body language to enter my car. The IR sensor must be dazzled by daylight and needs to be darkened to work, at least on my car.
Old Jul 24, 2016 | 02:43 PM
  #39
Roger Hansson's Avatar
c32 amg 2001 . and e55 amg 2003
i have this problem to. did as this guy.
Old Jul 26, 2016 | 01:28 PM
  #40
Dublinoh's Avatar
E63 AMG 2007
I have a 2007 E63 with keyless start. When I tried this in the garage no joy. But when my car was in the 90 degree sun flooded parking lot it worked. Just held down the unlock on the key. Tried to put the widows sunroof to closed position with the lock held down no joy. But I think the temperature in the car or outside must be a factor.
Old Jan 6, 2018 | 10:46 AM
  #41
Dooferdog's Avatar
E350 2009 C207
Repair Mercedes Summer Opening/Convenience Feature - YouTube
That is quality.
Old May 17, 2024 | 12:40 PM
  #42
Pierregirard's Avatar
Mercedes-Benz Vision EQS
Sometimes, key fob functions like controlling the windows might need reprogramming, especially if you've made changes to the car's electrical system.
