275/30/20 vs 285/30/20 vs 295/25/20 tires
04 E55 AMG, 03 350z Track Built/Single Turbo
There are some nice cars and wheels shown here.
With that tyre combo, the diameter of the rears will be 18mm larger than the fronts. The car will look jacked up in the rear.
If you wish to avoid a low profile, a 245/35 in front may be a better option. At least that’s my opinion.
That being said, as an update, they sold the tires out from under me yesterday so I had to ask them to order some new ones. They should be going on tonight.
W211 E55
Bbs LM 20x10.5 rear, 36 offset running 295/25/20. Slammed with no rub whatsoever. Had my rear fenders rolled and pulled a tad. Will run 305's with no problem when these tires wear out.
Remember moving up a width means roughly only 5ish mm of space needed on each side of the tire.
Just an update, went with Toyo 295/25/20's slammed, sport 2, spirited driving NO RUBS, infact tons of room still left for maybe a 20x10.5 with a 305 as long as offsets are good. Might need slight roll/pull but would look SICK.
E55 renntech
Wheels
I am having a set of Cargraphics 20x9.5 and 20x11 in the rear being done by B. Gorman I know i will have to roll and pull, However I was looking for opinons on tire size. I am going for the stretched look, B. Gorman sent me the centers of the wheels which my company is doing in Carbon Fiber and they are some heavy duty quality centers in my opinon. I dont know if anyone has any feedback on the cargraphic wheels. I would like to here some feedback. thanks.
#33
2005 BLK/BLK E-Double Nickel.
#35
Oh Damn Tony, nice choice! You make me wanna do smth Ive never wnna do again - run 20's. Damn you T.
#36
So, in terms of what is the correct fitment to maintain the most correct overall diameters and load ratings, what woulf be best for this:
20 x 8.5 (25 offset)
20 x 10 (35 offset)
2007 E63
20 x 10 (35 offset)
2007 E63
#38
E55 renntech
Cargraphics
Well they are being custom built from the ground up working togther. B.Gorman had the car for the day and we went over the different fitments from A to Z. so the offsets will be perfect. If they are alittle to aggressive we will bump it down to a 10.5 rear. The 11" rear will run a 4 inch lip. So I am pushing for that to happen, and with the right offset the tire wont need be stretched to the point you get it confused with an audi. We will see in the next week or so, My company is finishing up the carbon fiber centers and shipping them off to B. Gorman for completion. you can see in his video under classifieds some of the stuff we are working on together.
#40
2004 E55 AMG
I wonder what the ride quality is like on 25's. the sidewall is tiny so every bump in the road is probably amplified. Then you also have to consider what the extra pounding it does to your suspension. It looks great, but I am running 30's and can see a big difference in ride quality from stock.
#44
06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
On one hand we are all in love with 11 s in the back .. in my case on the CLS I can fit 11.5 rears with 305 easy with 9.5 fronts......on the other hand we are all trying to lessen the weight ! 11s will weigh more than 10 and 10.5 .. and the larger the tires the more weight also .. if the offsets are correct and planned right , one can achieve the best look with 8.5 fronts ( will take a 255 ) and 10 rear on the W211 and 10.5 CLS ( which will take a 285 nicely ) and save on weight .
what do you guys think .
#45
245/30
regret not going 20x9 and 255/30
