Secret AC menu
Old Jun 20, 2011 | 10:25 PM
Forrest Gump 9's Avatar
shrimp boat
Secret AC menu
I'm no sure if this is known yet, but I'm very sure the
#6 menu is the engine coolant temp
And I just found out today, the
#8 menu is AIT
Can anyone else confirm?
Old Jun 20, 2011 | 10:36 PM
jmb614's Avatar
E55 AMG
I saw a thread a while back that had numerous codes and their corresponding meaning, iirc Shardul posted a bunch of codes.
You should try one of the ELM327 bluetooth adapters with REV
Old Jun 20, 2011 | 11:33 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
https://mbworld.org/forums/3493950-post58.html
Originally Posted by shardul
Climate Control Data
When engine running hold REST button for 10 seconds. Use fan + - bottons to toggle
1 in-car temp
2 temp outside
3 heater core temp, left
4 heater core temp, right
5 evaporator core temp
6 engine coolant temp
7 refrigerant pressure (in bars)
8 refrigerant temp
9 not used
10 blower control voltage in range .8 - 6V (max)
11 air pollution sensor
12 sun sensor
20 control current of aux fan
21 engine RPM (x 100)
22 vehicle speed, km/h
23 terminal 58d battery charge, percent
24 battery voltage
40 software status register
41 hardware status register
Old Jun 21, 2011 | 12:57 AM
BenzoDoc's Avatar
2015 E63S 4Matic
If you figure out how to do it on an 05, I'd be nursing a semi at the very thought.
Old Jun 21, 2011 | 09:22 AM
jmb614's Avatar
E55 AMG
Try the AUTO button for 10 seconds. I think that is the button I used on my '06, but I'm not 100% sure.
Old Jun 21, 2011 | 09:50 AM
HeissRod's Avatar
https://mbworld.org/forums/3504153-post119.html
Originally Posted by JohnnyNg1981
Hello All,
Figured it out this morning....
For the 05-06 model's we hold the driver side AUTO BUTTON feature for 10 second's.
Once Climate Control Data menu pops up, use the driver side TEMP UP & TEMP DOWN for toggle.
Enjoy,
Johnny Ng
If you get a semi, don't post pics!
Old Jun 21, 2011 | 10:02 AM
Bullett's Avatar
2008 E63 AMG
Any Idea for the 08's ?
Old Jun 21, 2011 | 10:39 AM
09SL65's Avatar
An Amg
09 e63
Will this work on an 09 e63?
Old Jun 21, 2011 | 12:50 PM
BenzoDoc's Avatar
2015 E63S 4Matic
Auto + 72 + 72 does not work on my 05
No semi...yet...still hoping though!
I'm not the only one:
Originally Posted by gazan1204
I have tried every method listed in this tread and then some and I still cant get this menu. Any ideas as to why guy? It is a 2005 built in Feb 05
Old Jun 21, 2011 | 12:51 PM
BenzoDoc's Avatar
2015 E63S 4Matic
However, in the picture it's set to 75/75, maybe I'll try that.
Old Jun 21, 2011 | 02:36 PM
HeissRod's Avatar
It worked for me last July when I was having issues on the way back from Miami after buying my ride? I don't think the temp settings have anything to do with it. Just hold down the AUTO button for 10 seconds or so.
Old Jun 21, 2011 | 04:47 PM
Mantooth's Avatar
2004 E55 AMG
No IAT gauge?
BenzoDoc's Avatar
2015 E63S 4Matic
Tried to again today when I drove to lunch, gave up after like 30 seconds, has to be something to do with the de-optioning as this car progressed from 03-06, but I'm wondering why 06's have it if 05's dont.
Old Jun 21, 2011 | 05:21 PM
shrimp boat
Originally Posted by Mantooth
No IAT gauge?
I don't know, but I'm very sure it's #8. It behave exactly what the IAT read thru the scanner.
Old Jun 21, 2011 | 05:47 PM
lightningfast7's Avatar
2005 E55
Didnt work on my '05 either.
Old Jun 21, 2011 | 11:06 PM
HeissRod's Avatar
This was discussed in the hidden features thread. #8 is refrigerant temperature, not IATs.
Old Jun 22, 2011 | 12:41 AM
Ali_E55's Avatar
C218 CLS63TT PP Edition1, W213 E63S
it is not number 8. because it behave like scanner, but when you put the scanner and use the AC method. you can see the diffrence between the number. huge diffrence.
mine was 2005. and i couldn't use this option on the AC. but on my friends 2004. i saw big diffrence between scanner and #8
Old Jun 22, 2011 | 12:56 PM
pershing's Avatar
2005 E55
It does not work on my 2005 E55 (Holding down AUTO for 10 sec ) ;[
Old Jun 22, 2011 | 07:54 PM
gp500e's Avatar
2006 E55
Works on my 2006!
Old Jun 23, 2011 | 12:28 AM
HeissRod's Avatar
I tried it this morning and the menu popped up after pushing the AUTO button on the left for about 5 seconds.
Old Jun 23, 2011 | 12:24 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Not sure where the AUTO button is coming in on this. On my 03, it's the Off/Rest button that you hold for a few secs. Try that doc and others that can't get it working.
No need to worry bout temp, that was on the W210.
Old Jun 23, 2011 | 05:11 PM
HeissRod's Avatar
AUTO is the button used on the later models. We don't have a REST button. See post #6.
Old Jun 23, 2011 | 05:20 PM
BenzoDoc's Avatar
2015 E63S 4Matic
I actually posted a pic in the other thread about this, the 2005's don't have a Rest button.
Old Jun 23, 2011 | 06:40 PM
2005 E55
The picture above is the "AUTO" button as well..
Old Jun 23, 2011 | 07:08 PM
SvtAmg's Avatar
2005 E55 amg
I have an 05 and I have the REST button.
