Porting The SUpercharger
Old Jun 23, 2011 | 12:49 AM
Johncy2000's Avatar
2019 GLS63 AMG Diamond White
Has this been done before? If not I wonder how hard it would be to do.
Old Jun 23, 2011 | 01:36 AM
KLR CLS's Avatar
CLS63 PP
Can't really port this SC. You can port the TB snout some, but not really alot to work on there.
Old Jun 23, 2011 | 01:52 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Finny did some chop-chop... Getting surfaces to align neatly... Not sure of the gains...
Old Jun 23, 2011 | 08:20 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
There is not much hp you can gain by porting the S/C. The real thing is ported heads
Old Jun 23, 2011 | 08:27 AM
jmb614's Avatar
E55 AMG
Have I seen these heads on **************.com? They look nice, wonder when mass production will start
Old Jun 23, 2011 | 08:35 AM
Roverron's Avatar
ML63
I wonder what the gains or losses are?
Old Jun 23, 2011 | 08:45 AM
chawkins2001's Avatar
2006 E55 AMG
Are those yours shardul?
Old Jun 23, 2011 | 09:38 AM
shardul's Avatar
not mine yet. but they are being produced in houston.
one set has been installed on a CLS and the gains are healthy. boost drop and more power is made via these heads. The tension on the valve springs is also checked and brough back to spec via shims it needed.
I think the head porter will have another set ready if someone is interested.
Old Jun 23, 2011 | 11:12 AM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Larger valves?
Old Jun 23, 2011 | 11:22 AM
shardul's Avatar
Originally Posted by Jakpro1
Larger valves?
no new stock valves. one step at a time
BTW the person who ports these heads is the same person that some of the popular lambo shops use.
Old Jun 23, 2011 | 11:24 AM
Havoc's Avatar
2005 E55 AMG - - 2005 SL55 AMG - - - - - - 2006 SLK55 AMG - - - - - - 2013 Ducati Diavel AMG -
Larger valves?
Those heads have stock valves. You can see the difference compared to my ported heads with larger valves.
Old Jun 23, 2011 | 11:28 AM
shardul's Avatar
are those the VRP heads?
Old Jun 23, 2011 | 11:31 AM
Havoc's Avatar
This has been done a few times before, but with mixed results. It depends what type of mods you have. I would recommend porting the exit of the blower only.
Old Jun 23, 2011 | 11:32 AM
Havoc's Avatar
Yes they are.
Old Jun 23, 2011 | 11:48 AM
Jakpro1's Avatar
Thought they looked familiar.
Old Jun 23, 2011 | 11:58 AM
stevebez's Avatar
Kleemann also advocate and offer head porting ....
Looks like a very neat job in the pics btw...
Old Jun 23, 2011 | 01:57 PM
Johncy2000's Avatar
Should I port this? WHat is the exit of the blower? Sorry.
Old Jun 23, 2011 | 02:51 PM
Havoc's Avatar
Not really, this would be after every other mod possible since little gains are to be had.
Below is the exit of the blower. You want to port the "triangular section" that blows the compressed air into the intercooler.
Old Jun 23, 2011 | 02:59 PM
Johncy2000's Avatar
Wow that looks like a tough job. How many WHP are you running Havoc?
Old Jun 23, 2011 | 03:50 PM
Jakpro1's Avatar
Was talking to a guy in Jersey years ago who claimed with an adapter, he knew a guy who was running another blower. Just can't imagine the ECU of death accepting that but he claimed he was running a larger blower and getting great results.
Hmmmmm
Old Jun 23, 2011 | 04:13 PM
Havoc's Avatar
Yes, it's work intense. Zero, engine is currently disassembled.
Hmmmmm
Yeah, I agree.. Hmmmmmm. Our mad ECU would have a feild day with a different blower.
How is your beast running these days bro? You were one of the first guys to get to most mods and power out of the 55's back in the day.
Old Jun 23, 2011 | 05:31 PM
Johncy2000's Avatar
Are you selling your top mount intercoolers? I am definately interested if the price is right.
Old Jun 23, 2011 | 08:58 PM
Sher Judge's Avatar
2017 991.2 Turbo PDK 2017 C63S Coupe Ceramic Brakes 2015 CLS63S AMG Full House
Interesting and if you go with a 600 w220 TB and porting the rear of the charger, how many gains in HP? Does it make a difference really?
Old Jun 24, 2011 | 06:23 AM
Ali_E55's Avatar
C218 CLS63TT PP Edition1, W213 E63S
you can go with CLK DTM S/C which has bigger inlet and outlet. it can be seen in the picture.
but it will need a tune to switch off the below valve. as it comes without one.
part # start with 155 rather than 113.
Old Jun 24, 2011 | 07:29 AM
PTE's Avatar
PTE
05 ML-500 , 03 CLK5.5 AMG has left the Garage
Look closer & Check twice
Hey
Look at the Post #11. Check how close the valve head is to the spark plug exit hole & Thread?? This motor has oversized valves. and the travel angle when it opens . And the spark plug angle !! If someone index's the plug , so the J strap is at the intake valve . They will touch and BANG!!! I remember about 4 years age VRP in Cali. Had a spark plug crushing Issue! and even posted some of the damage . Then about 2 years ago the motor had a exhaust valve clearance Issue . from a Valve float at hi rpm . I’m now thinking quite different HUMMM
Cheers _PTEngineering
