E55/SLR Injectors
Old Jun 25, 2011 | 03:02 AM
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
E55/SLR Injectors
I'd like to know if anyone has ran these injectors, or know flow wise how they compare to our stocks? Thanks for any help.
Old Jun 25, 2011 | 04:50 AM
ahmad0658's Avatar
Brabus K8 E55 05
one or two words
TTM Bruce
you will get your answers with him
Old Jun 25, 2011 | 08:09 AM
jmb614's Avatar
E55 AMG
+1 Bruce at TTM
If you get his injectors, Jerry from Eurocharged has a lot of experience scaling them.
Old Jun 25, 2011 | 10:50 AM
Evolved8's Avatar
AMG Fam
Dosen't Bruce at TTM use SLR injectors?
Old Jun 25, 2011 | 11:45 AM
Hammer Down's Avatar
2015 E63S, 2018 E63S
No
Old Jun 25, 2011 | 12:57 PM
TTMotorsports's Avatar
Former Vendor of MBWorld
Whatever we're tuning!
I do not use SLR injectors. My injectors are dual fan spray pattern and are larger than the SLR injectors.
Jerry from Eurocharged is the ONLY TUNER with experience tuning the TTM Injector and Fuel Rail Kit and I know he has worked closely with Shardul. I believe he has well over 50 hours into this file.
Old Jun 25, 2011 | 03:00 PM
jcjmw's Avatar
2005 E55 Wagon
+1......I know from personal experience. You can not go wrong with this tandem!
Old Jun 25, 2011 | 08:19 PM
PACougar's Avatar
I've seen the injectors on eurocharged website and I just spoke to them about the injectors they carry. I'm probably going to go with theirs now, however I haven't seen the fuel rail kit?
Old Jun 26, 2011 | 12:01 AM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
I have been running SLR injectors (they have 6 ports) for about 2 years with a closed loop rail. Never been on the rollers, but there is a noticeable improvement in response and power. Certainly a better spray pattern and atomization.
Old Jun 26, 2011 | 01:56 AM
PACougar's Avatar
That's good to know in case I do go with the SLR injectors, at least someone has had good success with them. I'd still like to know about the Fuel rail kit.
Old Jun 26, 2011 | 11:51 AM
jcjmw's Avatar
2005 E55 Wagon
If you do a search for TTM fuel rail, you will find threads about it and with pics.
Old Jun 26, 2011 | 02:11 PM
MBTEK's Avatar
06 E55, 03FORD P/S,01 E320-4M,99 ML320,O4 E55,05 RUBICON UNLIMITED,
I will be running SLR injectors in my car,I know of a couple of other people running them also.You will be able to take away around 13-15% duty cycle from your stock injectors and tuning.The one buddy of mine who is running SLR's,after tuning , saw the car get 24+ mpg on the highway(via cluster) on a 300+ mile road trip.
Old Jun 26, 2011 | 03:39 PM
AMGPilot's Avatar
2004 E55
Sounds like the cluster wasn't scaled for the new injectors
Old Jun 26, 2011 | 06:15 PM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
what are slr injector rated flow rate and what is stock injector flow rate?
Old Jun 26, 2011 | 06:16 PM
stevebez's Avatar
Are you running TTM's rail kit?
Old Jun 26, 2011 | 07:14 PM
Using a little larger than stock injector(SLR) will decrease IDC but the real issue is the fuel volume distribution and how the stock rail builds pressure.
Just increasing injector size is only part of the equation and it isn't even the most important part of it.
Anyone that is running the SLR injectors(or any injector running slightly larger than the stock 440cc) with a stock fuel rail should put an EGT probe in #5 and #8 and I am sure the temps in #8 will still be significantly higher on top of 3rd into 4th high speed runs. This is when the fuel starvation issue rears its ugly head.
Just my .02!
Old Jun 26, 2011 | 07:18 PM
Steve does not have my rail. He is an extremely knowledgeable and stand up guy who really enjoys this stuff. I believe he had a closed loop fuel rail on his car well before I started building them.
Now if he would only get rid of those cats and set another road course record with his E55.
Old Jun 26, 2011 | 09:51 PM
AgSilver's Avatar
No - - - I made my own at the time, but TTM's appears to be very well done.
Old Jun 26, 2011 | 10:09 PM
AgSilver's Avatar
Bruce - - -
I'm done with any additional mods except for some K-MAC's on the front end (Evo's toe links are already on the rear). I'll be back in Germany in about 10 days and try to run some test laps at the Nordschleife in August. It all depends on our schedule and the availability of my friend who will drive the car (he's won there for Porsche and has more than 1000 laps - - - that in itself will more than make up for running cats). That notwithstanding, it's still a pretty sneaky autobahn marauder.
I think it's time to start thinking about a 6.3TT, in about a year or so.
I'm in Southampton and will see if I can sneak away and stop by later this week.
Old Jun 26, 2011 | 10:19 PM
Johncy2000's Avatar
2019 GLS63 AMG Diamond White
Should this be my next mod after my 82mm TB? Will I get more power?
Old Jun 27, 2011 | 03:34 PM
MBTEK's Avatar
If memory serves me correct and I will edit this if it differs,data logging with the SLR inj.'s with egt probes in #5 and #8 resulted in about a 35-40 degree difference on the 1320 run as well as a blast to 120mph. The biggest problem I see is that most of the people who mod these cars(not all) use no kind of data logging equipment,whenever you start adding power you need to know what is going on with your engine/fuel system or you will enjoy the costs of rebuilding/replacing your engine.maxing out your IDC on stock injectors is bad,over fueling is hard to tune(to big of injectors),I feel with 15% increase in fuel flow from the injectors,tuning being easier? to dial in from not dumping so much fuel is a safe bet.I'm not saying you won't need more fuel but without datalogging to see what's going, you're driving blind.I am in no way a tuner so I don't know all the ins/outs of tuning,I just know from the cars I have done what seems to work while being safe. A full loop fuel rail is great upgrade wether it's slightly modded or fully modded,also,one of the fastest e55's in the 1320 is running Slr injectors,gets datalogged daily and runs the stock fuel rail and has no issues
Old Jun 27, 2011 | 04:46 PM
Excellent info in your post from your extensive experience with these cars.
The fuel starvation and maxed IDC's happens at the top of 3rd and well into 4th and that is where these engines are getting hurt. Running down a 1/4 mile will not duplicate high speed pulls at the top of 3rd and going into 4th where this issue is apparent. The SLR injectors help lower the IDC's but he is still going to drain the fuel rail on a 140-150mph run but I know he doesn't run his car like that. He is also tuned for the 1/4.
And for the record........Alan's car is a complete BEAST and, with your experience and all of the data logging that you guys do, you have built a BAD A$$ 1320' car!
Old Jun 29, 2011 | 04:44 PM
Bramage's Avatar
F-250
I agree with: Bruce, Scott, and the absent Alan. Bottom line: Static Injectors=BAD!!! There is always a number of ways to skin a cat, and I will soon be testing these waters.. stay tuned for more
Old Jun 6, 2013 | 05:24 AM
StuttgartAMG's Avatar
E55 AMG (W211)
I bought a set of SLR-injectors.
They do about 25% more flow, so you can reduce the length of cycle and thats better for life expectancy of the injectors.
They also have better spray than stock injectors, because of one more injection hole.
Old Jun 6, 2013 | 03:25 PM
AgSilver's Avatar
Ich denke, Sie werden feststellen, dass es 6 Löcher.
