P0106 Cel
Old Jul 2, 2011 | 12:52 AM
tbal's Avatar
Haters crazy
P0106 Cel
Did tb shaft grind week ago had an error code but it went away after a throttle body reset. Now have a p0106 error and cel. Car runs ad drives fine but ? Any thoughts?
Old Jul 2, 2011 | 07:36 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
boost sensor. check the connections
Old Jul 2, 2011 | 02:38 PM
tbal's Avatar
Haters crazy
Where is that sensor? Could a loose ypipe causing this error?
Old Jul 2, 2011 | 04:29 PM
skratch77's Avatar
2005 E55
did you clear the code and have it come back?I threw this code twice when I had the EC tune on my car.
Mine was probably a leak but it never came back after the second time I cleared it.
Old Jul 2, 2011 | 05:03 PM
shardul's Avatar
passenger side under the s/c
Old Jul 2, 2011 | 05:48 PM
jcjmw's Avatar
2005 E55 Wagon
Boost sensor same as the MAP sensor?
Old Jul 2, 2011 | 06:02 PM
jcjmw's Avatar
2005 E55 Wagon
Maybe this might help. Take a look at post #2 in this thread:
https://mbworld.org/forums/w211-amg/...-tb-codes.html
Old Jul 2, 2011 | 06:21 PM
shardul's Avatar
yes
Old Jul 3, 2011 | 04:15 PM
tbal's Avatar
Haters crazy
How can I seal the y pipe better? I think thats my problem as upon closer inspection the bottom clip on the y pipe is broken!
Old Jul 6, 2011 | 07:53 PM
tbal's Avatar
Haters crazy
Anyone?
Update, CEL has disappeared, and yet to return... hmmm
Old Jul 6, 2011 | 08:18 PM
jcjmw's Avatar
2005 E55 Wagon
Anyone?
That's interesting, but good news for you. Maybe you just needed to drive around for awhile(?).
Old Jul 6, 2011 | 08:19 PM
benz_addict's Avatar
V12TT
the sensor is like 80 bucks and is a ***** to get to if you're trying to install it without removing the supercharger. It can be done but its hard and you will need patience. I know this sensor shares power or ground with other sensors but i doubt it's wiring problem. Replace the sensor clear the light.
Mine came back though and keeps coming and going but for now it's good and it drives fine I live with it.
Old Jul 6, 2011 | 10:01 PM
tbal's Avatar
Haters crazy
Any DIY's to replace the sensor? Part number? Where the heck is it anyway lol...
Cheers
Old Jul 6, 2011 | 11:45 PM
jcjmw's Avatar
2005 E55 Wagon
Cheers
Here is how NOT to replace the MAP/boost sensor
https://mbworld.org/forums/w211-amg/...iy-thread.html
