Time for new tires ... what to get?
Hook up is great, noise is low - don't know about wear yet.
I have had 295s on the rear with no rub for years, but the Hankooks seem to run a little over sized.
They sit very tight in the wheel wells (i'm lowered as well)
I can't see any rub, but I've only had them for a few hundred miles.
They don't hook up as well as some of the high dollar summer tires, but they are a few hundred dollars cheaper.- get what you pay for
I always found I ran through the super soft tires in under 10K miles. I do a ton of highway miles, so changing tires twice a year was getting old.
I had potenza's on their before and they were lasting 20K miles, but they don't hold air well and the grip wasn't great.
Do a quick search on here and you will see a ton of recommendations for you to read
Hope this helps
I agree. How long should I expect the V12 evo K112s (or whatever it is) to last...?
TPMS sensor generally generates a light in the dash if the pressure goes low. If you have ever seen that light come on, then thats another way to tell if you have TPMS sensors on your vehicle.
Tirerack is asking whether my car comes equipped with this or not? With TPMS or Without TPMS?
My manual talks about the E-series in general, nothing specific about the E55 and doesn't mention anything about the TPMS.
Visually, I can't see anything different on the valve stems on the car.
Any help? Thank you.
G
Michelin PSS cost more but I have only heard great things about them, Cheaper then PS2's, better tread wear and more grip.
Hankook's........................$170.00 each
Car and Driver Magazine Tire Test
1st. place...................Michelin PS2
2nd place...................Hankook
Like most of you, I replace rear tires at least once a year. I'm on my 6th pr. of rear tires now and my second pair of Hankooks in five years. Are the PS2's a better tire? IMO, yes, but not worth the extra bucks. The Hankooks are very close.
I'm not that an aggressive driver and don't track my car so they're fine for me.
i have a s550 and want to keep the noise level down with 20's.
Thanks!
