Loud belt squeal coming from under the hood *video*
Old Jul 5, 2011 | 05:40 AM
Mantooth's Avatar
2004 E55 AMG
The pulley in question is also wobbling. What is this pulley for?
Thanks!
http://youtu.be/ICyl8a2I794
Old Jul 5, 2011 | 07:31 AM
chawkins2001's Avatar
2006 E55 AMG
Looks like the idler pulley bearings are bad. You need a asp idler or OEM replacement.
Old Jul 5, 2011 | 07:36 AM
Mantooth's Avatar
2004 E55 AMG
That's what I was thinking. Calling tomorrow to get the other two ASP pulleys.
Could this be the culprit to my overheating at idle issue?
Old Jul 5, 2011 | 07:51 AM
2006 E55 AMG
If it is the water pump pulley possibly. Don't think the idler could cause that unless it was causing a drag on the other pulleys.
Old Jul 5, 2011 | 10:20 AM
GT-ER's Avatar
2005 E55 AMG
Remove the belts and check your pulleys. It's a 15 minute job and you can be SURE where the problem is. I agree that the idler or tensioner pulley could be at fault.
