Rear Toe Links and Camber Arms vs K-MAC Bushings
Guys, I try to get more stability and traction and less tire wear. I am just STAR lowered and not planning to go any lower.
What would you recommend MB arts Toe Links and Camber Arms or K-MAC front and rear bushings or combination of both ?
I like the idea of the bushing as they will be less squishy that the stock rubber ones, with the added benefit of being adjustable. Question do they need maintenance ? (being readjusted regularly)
What is the crowd wisdom ?
I Installed k-mac up front and Arms rear. Tire wear is totally even on all 4.
No maintenance carried out since the install at the begining of the year.
I did get a sqeak over bumps on one of the rear arms that lasted a few weeks when the weather was cold.
Goodluck
Goodluck
^ I could not disagree more. With my mods, I could not keep the rear straight under load. I would track all over the place, and that can be scary.
I installed the arms, got a good alignment, and the rear is solid. As for camber, I don't know, and I don't care. I am slammed
In terms of keeping the rear end in place- they work perfect. I have had them on over a year, and no issues. I have no experience with the KMAC stuff, but there are a lot of writes ups, both for and against.
No maintenance is required for the K-Mac bushings, and the camber, caster and toe adjustments will remain intact unless something unforseen happens.
These are not 'positional' bushings that need to be installed in a certain position to set the alignment, but they are adjusted after installation and serrated ends on the bushings grip the crossmember (etc) and hold them in place. The urethane bushes are pre-greased for life on installation, those with inner steel bushings have a hard-chromed surface with grease grooves cut into them.
And if you're looking at putting bigger rubber on the rear, the K-Mac bushes won't push the top of the wheel out to rub on the fender like the adjustable top arms do.
I just had the K-mac bushings installed all around, fronts are good and I can get the car into the factory specs even though I'm pretty low. I am having a problem with the rear toe adjuster as they keep moving, the rear camber bushing seem fine though, I called K-mac and they sent me some new bolts, nuts and washers with a fine thread for more clamping force for the rear toe adjusters and a new set of rear camber bushing saying that these are updated to a new spec which really pisses me off seeing as I just bought these and paid to have them installed and the rears are a PITA I'm told, I've been waiting to get these sorted out before I do a write up on them, if I can get the rear toe sorted out these seem to be the way to go, I will follow up with this thread either way,
