Defrost Always Blowing Air
Old Jul 7, 2011 | 03:02 PM
drjones's Avatar
2004 e55
I just bought an '04 E55. I love the car and I am currently taking care of the few issues it came with.
The right side defrost vent always blows and the passenger side vents are always blowing weak (defrost robbing some airflow). This happens in auto and manual settings.
Second issue. The AC compressor sometimes does not engage after start for a few minutes (seems to be when the cabin is really hot) until I get the engine rpm up a bit. Cools good once its on. This first appeared after I used the rest function after shutdown but now it is random.
Any thoughts?
Is there a button combination that will reset the ventilation door/flappers?
Old Jul 7, 2011 | 03:20 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Any thoughts?
Make sure the two round dials are clocked around to the desired discharge location.
Old Jul 7, 2011 | 06:25 PM
drjones's Avatar
2004 e55
Dials have no effect
Same result auto or manual with dials at any position.
Gotta be a stuck door/flapper.
Any way to reset?
Old Jul 7, 2011 | 11:04 PM
Ok there are 3 diagnostic tests you can do from the A/C control unit, one displays sensor values, the second recalls fault codes, the third tests the flap controls.
I found the directions for the first test here,
Old Jul 8, 2011 | 08:52 AM
drjones's Avatar
2004 e55
Testing the vent flaps
Thanks, I know how to get the sensor values to display. Anyone know how to test/reset the vent flaps?
Old Jul 12, 2011 | 08:49 PM
Found this for w210, many functions are the same in the A/C controller.
http://www.underhoodservice.com/Arti...h_surgery.aspx
If this won't work then try starteck.
http://www.startekinfo.com/StarTek/
