- Mercedes-Benz E-Class How to Replace Rear Shocks
Step by step instructions for do-it-yourself repairs
Need a little help on W211 E55 right rear strut replacement
http://www.autohausaz.com/search/pro...ock%20Absorber
and here is pelican parts:
http://www.pelicanparts.com/euro/cat..._pg1.htm#item0
both reference 2113260100 as the correct part unless model with chassis serial number from A334971 or X108180. then part 2113262800
so i am thinking its part 2113260100
I believe it is suggested by the service manual to use STAR to release the pressure from the air spring when doing this repair. I did not use STAR to release the pressure and the only thing that happened was the spring was able to open much further (and quickly) when the shock was unbolted. A little surprising when you aren't susecting it, but everything returned to normal once the repair is finished and the car is lowered off the jackstands and started.
I had forgotten there were different part numbers based on vin number of the vehicle. My number obivously fit with the numbers associated with the 62800 part.
I guess it would depend on what the VIN of your vehicle is. I have no idea what changed during the build that required different part numbers.
