Approximate horsepower after mods
Old Jul 14, 2011 | 04:32 PM
edmond1129's Avatar
E55
Question Approximate horsepower after mods
After owning the beast(MY2003) for about a year now and modded a few things, and it is kind of hard to find a dyno here, so could anyone estimate approximately how much power I should have, crank and wheel?
PLM header, second cat and resonator removed and replaced by x-pipe, PLM HE and Johnson CM30, Eurocharged tune, Eisenmann exhaust, K&N and 98 octane gas.
Also, it is getting some vibration during idle, i changed those rubber mounts already and still the same, so what could be the problem? Cracked piston?
Appreciated for any input, thanks.
Old Jul 15, 2011 | 01:15 AM
E55Bullet's Avatar
2008 ML63 2009 SL63 2010 Alpha 7 GTR
Try changing your plugs, are you going to upgrade your pulley?
Old Jul 15, 2011 | 01:21 AM
AWOL's Avatar
e55
Id guess 450-460 wheel on a dynojet
Old Jul 15, 2011 | 02:03 AM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Got to be more than that.. I did 436 on a dynojet with just intake and exhaust... Id guess at least 475, probably a bit more..
Old Jul 15, 2011 | 02:10 AM
edmond1129's Avatar
E55
Spark plug changed, so i worried it is something else, it feels like a in-line four engine. I am quite satisfy with the power i have now, so i will leave the pulley later.
Old Jul 15, 2011 | 02:18 AM
edmond1129's Avatar
E55
Thanks for the input guys, so i should have over 500 crank HP in this case then
Old Jul 15, 2011 | 04:02 AM
I Like Soup's Avatar
2003 E55 AMG
Yes, especially considering stock the car has 500 crank hp. I would guess you picked up around 30 hp or so...
Old Jul 15, 2011 | 08:59 AM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
I would go for a pulley too! Are you in Hong Kong? Are there any Dynos there? I pass through Hong Kong every 2 months or so ... but only to get to China ... stock car has 500HP? I thought it was 469?
Old Jul 15, 2011 | 02:20 PM
edmond1129's Avatar
E55
I didn't want to touch the engine too much, cus most of the parts need to be ordered by local retailer (don't need to think about from the dealer here cus most of the case it charge 3-4times the actual parts cost), and it takes about a month or two to arrive in here(E55 is not common here, and most of them are bone stock, so they don't kept much parts), so if anything goes wrong, the car might need to sit there and wait. Just like I got my front airmatic failed 2 months ago and the local retailer said it will take 6 to 8 weeks for shipping, so I asked a friend to buy the suspension for me when he was in singapore, 3 days back.
There is a garage here which can do dyno, but it doesn't always available, I think I will try to do it once, just need to book them quite a long time before, once I have done sure will post the result here.
The beast is 469HP stock, just want to know about how much power I have after those mods before dyno, cus you know these guys here are real pro man.
Old Jul 15, 2011 | 05:37 PM
2003 E55 AMG
Do some diggin' around the forum fellas, the car is pushing 500hp stock. The 469 figure is marketing, if nothing else. Can't have the SL's and S's making the same horsepower as an E!
Old Jul 15, 2011 | 07:19 PM
AKnight55's Avatar
Yea the stock hp is really closer to 500
Old Jul 15, 2011 | 08:03 PM
e500slr's Avatar
2011 E63, 2013 CLS63
....did you count how many cylinders it has just in case it's not an E55 :P
Old Jul 15, 2011 | 10:42 PM
turbo97se's Avatar
Cool thanks for the info .. guess I never really researched it. Nice to know! All I know is when I first got mine it felt fast ... now it feels slow. Time for some mods
LOL hopefully he didn't buy it in China ... famous for fake goods!
Old Jul 16, 2011 | 12:00 AM
tony.damore's Avatar
2013 SL63 AMG PP
Sounds crazy but my E55 did the same exact thing, only when cold. Felt like one or two cylinders were not firing. I also had a totally different problem with the interior lights flickering slightly at idle. Changed the voltage regulator, fixed both problems PLUS the problem of my sunroof not auto closing AND my fixed the problem with my A/C not working on the highest speed. Totally serious, did the work myself.
Old Jul 16, 2011 | 12:07 AM
skratch77's Avatar
2005 E55
I dono,I did 400whp 100% bone stock and dont those sl55s have a better exh and 80mmTB ?
Im sure there tune is more agresiive also.
Iv seen a dyno of an sl make 530whp from just a 168mm pulley,headers and tune
Old Jul 16, 2011 | 12:49 AM
2003 E55 AMG
Sure, do the math...at an 18% drivetrain loss, you should be around 410hp if it were ~500 crank hp, so you are right in the ballpark, thanks for verifying!
For mods, check out what I have below and I dyno around 410whp out in Southern Cal, but the dyno at DynoComp here in the Valley, I'd dyno 100whp more since Hooleyboy has the same mods and is right around there.
