New Rear Mount Reservoir (Thanks Shardul!)
1 Post
2008 ML63 2009 SL63 2010 Alpha 7 GTR
Hey guys! I got my new rear mount tank in from Shardul and it is perfect! Build quality and welds are top notch! I just cant wait to get it all hooked up.
-Chad
-Chad
1 Post
Its a very expensive flask!
Jk
It is mounted in the trunk to expand the amount of cooler coolant for the HE/SC. pretty much it makes the car recover and run like say a 60 degree day in 90 degree heat. It will also make recovery time less and keep air intake temps down for runs. Keeps the car less prone to heat soak..
Jk
Thanks again to the "Go To Man"
1 Post
Shardul is "The go to Man" He is helping me with other things as well! A great asset to the community!
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
I learned quickly how expensive fitting can be so on the new design i asked the fabricator to to weld on the 90 degree inlet and outlets so people wont have to spend additional on fitting.
1 Post
Its a 3.5 gallon tank with about a gallon in the lines so a total of 4.5 gallons. It does require a rule 2000 bilge pump. I believe (you can see in the pic) where the mounting bracket is.
Interesting. I would like to see pics of it mounted with the lines in place. Seems like an awful long way to pump the coolant. But I suppose that long distance allows it to cool down more.
The internal bilge pump pushes the water up to the meziere wp136s through the heat exchanger to the IC then out back to the tank.
V12-Biturbo
Jeez I listed the real tank builder here over a yr ago & now Shard is reselling Donnys tanks herehttp://dadscustomintercoolertank.com/services.html @
nearly DOUBLE the price
ie $220 w/Shard vs $120-$130 if you order directly thru
Donnys site phhhbbt "way to take 1 for the team there Shard"
Use the search function here guys, I listed everything needed hoses fittings pumps inc cm30 or new MB pump, MINUS Shard middle-man pricing..
V12-Biturbo
Donny Bail tanks site..
1 Post
1 Post
T!! Its pretty much a must for controlling the AITs. There has to be numbers floating around here somewhere but youknow how threads get tied up with lotus's and such. There is an internal bilge pump that is required to push back to the s/c. I just got one for the price above.
2017 991.2 Turbo PDK 2017 C63S Coupe Ceramic Brakes 2015 CLS63S AMG Full House
