SDS DIY Mods
Old 07-20-2011, 11:09 AM
djrabbi's Avatar
CLS550 4Matic, C43, E350, ML350
Ahh yes the radio thing is quite annoying....would love that too!
Old 07-20-2011, 11:13 AM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
With star you can rear vital engine parameters. For example you can see knock on each cylinder, flow in each injector etc etc
Old 07-20-2011, 11:17 AM
bobgodd's Avatar
2004 E55
I believe it was Hyevon that did it, hopefully someone can confirm.
Old 07-20-2011, 11:22 AM
Gus83's Avatar
2009 E63
yeah gus thanks for all this....I am sure when I get mine in, I will make PDFs for each mod and make sure it is a sticky!
p.s. when lowering, should the front be the same height from the get go? When i look at my car sometimes, seems driver side is lower. So my question is.....when i get into the system will it say i am off by x.xx amount?
You can go to actual values so you will see if is kinda level, but you are supposed to level it while you lower it, the surface needs to be as straight and level as possible.
Old 07-20-2011, 11:24 AM
djrabbi's Avatar
ohh okay got it! so when i get into the system it will tell me off the bat if it was level....i have links on them now, just want to go a tad bit lower in the rear
Old 07-27-2011, 12:21 AM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
Hey guys
I got my DAS Developer key to work. I now have the DAS developer mode. My system, when I got it did not have developer mode. You need to get a Key to activate it. However, when I try to transfer the coding for VMax=300. I get the following error ... Anyone seen this? I managed to set Rest of The World OK. For the Keyless GO reminder, I did not have to set it. Setting to Rest of The world just seemed to turn it off. I guess the rest of the world doesn't want that reminder either Any thoughts on this error message? Thanks!
Old 07-27-2011, 08:41 AM
  #32
djrabbi's Avatar
I can't even get there...after I click on 211.....gives me faulty errors....i just plug everything in and did it from there....am i supposed to do something prior to this?
Old 07-27-2011, 12:06 PM
  #33
turbo97se's Avatar
If your serial port is USB to serial, that is likely your issue. I encountered the exact same issue when I used a USB to serial converter. Some people have reported some success with certain converters, I have not. If you can hear relays clicking on and off in the scanner, you're in good shape (as far as serial port is concerned).
Otherwise, it is likely that your serial port settings are not set up correctly.
Old 07-27-2011, 12:07 PM
  #34
djrabbi's Avatar
yeah i have the USB to serial...which shardul told me same thing...I just ordered new HDD and IBM laptop for $70 off eBay!
Old 07-27-2011, 12:53 PM
  #35
turbo97se's Avatar
Cool .. well don't buy too cheap of a laptop. Depending on how you are running the SDS. If you are using VMWARE, an old laptop will be super slow. If you are using direct install to the laptop as a dedicated machine, you should be fine.
Old 07-27-2011, 12:55 PM
  #36
djrabbi's Avatar
got the IBM T30 and shardul hooking me up with a direct HDD so would be good!
Would you know the DIY for gallons left and rain sensing windows?
  #37
shardul's Avatar
he is using a direct install not a virtual machine
Old 07-27-2011, 12:56 PM
  #38
xpl0sive's Avatar
CLS55 AMG
i'm pretty sure you can change that in the settings on the cluster. on my old 2004 CLK I could change between scrolling through presets and radio tuning.
Old 07-27-2011, 12:57 PM
  #39
djrabbi's Avatar
i don't think you can.... e and CLK have different systems
Old 07-27-2011, 01:12 PM
  #40
xpl0sive's Avatar
CLS55 AMG
ah yes you're right...
CLK has the option for it and E class doesn't. it should be under Vehicle.
Old 07-27-2011, 02:14 PM
  #41
timeToy's Avatar
'08 E63 Wagon
my '08 E63 has that option
Old 07-27-2011, 03:16 PM
  #42
turbo97se's Avatar
Is there ANYTHING that Shardul doesn't know ? LOL ... Yeah you'll be in good shape. Do you have install discs? I am looking to reinstall or upgrade mine. Mine is 2009 version and looks quite a bit different from Gus' ... I see some pre/post cat O2 sensor stuff in the menus ... might need those for my headers that are coming! I'm still learning the system. Quite a lot more stuff to tweak than BMWs GT/Progman systems! It's pretty intimidating!
Old 07-27-2011, 03:17 PM
  #43
djrabbi's Avatar
i didnt get any discs.....ask shardul lol
Old 07-27-2011, 03:22 PM
  #44
shardul's Avatar
are you running it as a virtual machine or direct install?
Old 07-27-2011, 03:39 PM
  #45
turbo97se's Avatar
I am running as Virtual Machine ... but I can do either or both ... if I have the install files. I have had to do it multiple times with BMW stuff ... BMWs are harder to install for sure since they run Linux SCO as base on the older GT1s and XPe on later Progman. This should be cake on Windows!
Old 07-27-2011, 04:59 PM
  #46
Gus83's Avatar
2009 E63
Not to say something but I thought the point of this thread was so it didn't turned like the old one, to much gibberish and not enough info. All I'm saying is, it would be better to keep the thread cleaner than what it is now.
Old 07-27-2011, 05:42 PM
  #47
turbo97se's Avatar
Not to add more gibberish ... but you are right ... any way to delete all the non-related stuff? Maybe mods can help ... sorry!
Old 07-27-2011, 05:57 PM
  #48
Gus83's Avatar
2009 E63
It's all good man lets just try to keep it cleaner now, I'm on the process of trying to figure out couple more stuff to post, if anyone needs anything I'm always here too
Old 07-28-2011, 03:05 PM
  #49
djrabbi's Avatar
found this site......
http://www.mercedestechstore.com/pdfs/index.htm
Old 08-03-2011, 10:54 AM
  #50
djrabbi's Avatar
I enabled the fuel tank capacity but doesn't show up on the cluster? Any reasons?
Quick Reply: SDS DIY Mods
