SDS DIY Mods
#52
ohh nice...I thought maybe "resetting" the cluster would do it haha....
I found the rain sensor one but doesn't give me a option for rain sensor to enable?
#54
The tank display showed up on mine almost immediately. After enabling it, I got out of the car and locked the doors for a couple of minutes with the key and then unlocked it. Started the car, went to the fuel (after start screen) and hit the down arrow until i got to the section that shows it.
As far as fogs as DRLs I was very interested in that but did not find it. Only fog feature i found was the turning/curb lighting feature, which gets real annoying when you have HIDs
#55
yeah i got mine to work after "restarting" the cluster.....
have you done the rain sensor? i cant seem to figure it out
#58
Did it a while back among other things but try this.
Control units ==> Body ==> OCP ==> Initial Startup ==> Initial Startup with manual settings input...
Follow the steps and select Active for the "Closing of tilting/sliding roof when it rains as pictured below (from DAS SIM).
![](https://lh4.googleusercontent.com/-MqpYRqP4ZSc/TkFipyQ31rI/AAAAAAAAAfk/FqhvJhfQXts/s800/sunroof%252520close.png)
#60
Never tried it but if I were to take a guess from experience on previous cars I'd say it auto closes the sunroof when you shut off the ignition.
#66
I find a lot of issues with all this coding. I did some of these and coding of the mirror folding and they just don't seem to take sometimes.
Thanks for the seatbelt chime one. I have been searching around for that one. I wear my belt most of the time but when I don't at low speed (almost never
) its sooo annoying!
#67
ok i've got a few quotestions/ comments.
no need to turn off keyless go if you don't want the reminder. just do the following
Setting to change for "Rest of the world (RDW)" and "Keyless GO"
- On main groups go to "control Unit"
- then to "Body"
- then to "CGW"
- then to "development data"
- then to "Control Unit Adaptation"
- then to "Control Unit Adaptation (Variant Coding)"
- then to "Globale Variantencodierung Draco"
- the first or second option should say "US" or "USA", replace that for "Rest der welt (RDW)"
this will turn off the warning among other things.
i've got a question about lowering my CLS. When i click on 219, it goes to the next menu. I do not have the option to select "Functions performed by more than one control unit"
there are only 4 options to chose from. Am i supposed to be going into 211 instead? i tried that, it would not recognize the car. It asked me to select the production date... which one should i go with?
- then to "Body"
- then to "CGW"
#69
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
#75
Hey guys. How do I change the setting to Phone Present with star? I installed mobridge and want the menu to show up in my instrument cluster for the phone...
