Any body re-using their stock intercooler?
Old Jul 27, 2011 | 01:32 PM
jcjmw's Avatar
2005 E55 Wagon
For those with upgraded HE or trunk reservoir, I was curious if you found a way to re-use the stock intercooler?
Old Jul 27, 2011 | 01:48 PM
AMG_RL's Avatar
E55 AMG, 72' Toyota Carina, 63' Ford F100, 72' Mercedes 250c, 15' Harley Davidson Softail
you can run an aux HE in conjunction with the stock intercooler, that's what I'm going for I believe Shardul has this setup as well.
Old Jul 27, 2011 | 01:51 PM
tbal's Avatar
Haters crazy
Re use stock intercooler? Don't you have to use the stock intercooler regardless?
Edit oh heat exchanger. Yes you can run 2 small ones in series with each other. I decided to do one big one instead.
Old Jul 27, 2011 | 01:56 PM
jcjmw's Avatar
2005 E55 Wagon
Can you by chance post a pic? Where did you put the stock intercooler in relation to the larger HE?
Old Jul 27, 2011 | 01:58 PM
tbal's Avatar
Haters crazy
Shardul left stock as is, and new one infront.
Old Jul 27, 2011 | 02:15 PM
GT-ER's Avatar
2005 E55 AMG
My EC intercooler is too big.
Old Jul 27, 2011 | 02:32 PM
jcjmw's Avatar
2005 E55 Wagon
Likewise, the larger HE I have does not allow me to reuse the stock intercooler in the same location.
Anybody re-using the stock intercooler but in a different location?
Old Jul 27, 2011 | 02:33 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
What do you mean?
Old Jul 27, 2011 | 02:45 PM
GT-ER's Avatar
2005 E55 AMG
Originally Posted by Hammer Down
What do you mean?
The stock one won't fit because the EC is too big. There is no room to fit the oem one.
Old Jul 27, 2011 | 02:54 PM
Originally Posted by jcjmw
Likewise, the larger HE I have did not allow me to also use the stock intercooler in the same location.
I'm sure that the two of you already know this but if you run a rear tank you won't need to run a 2nd heat exchanger.
Old Jul 27, 2011 | 02:59 PM
GT-ER's Avatar
2005 E55 AMG
Heck, as it is right now my temps are pretty decent even on the stock cooling circuit.
Old Jul 27, 2011 | 03:13 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
i have seen a stock size ic mounted under the rear bumper for additional cooling before the water goes into the trunk tank
Old Jul 27, 2011 | 03:19 PM
pimpjuice's Avatar
2003 E55 AMG
I have an S55 one in front with the stock HE on the bottom jsut for the SC and have absolutely no Heat Soak issues.
Old Jul 27, 2011 | 03:23 PM
jcjmw's Avatar
2005 E55 Wagon
Yes. I was trying to find a way to re-use that stock intercooler that is just sitting in my garage closet. I was thinking of running the lines from my soon to be installed rear tank to the stock intercooler then to the front of the car. In the wagon, the under the rear bumper, there is space between the rear bumper and the spare tire space that can actually hold the stock intercooler. I tried it last night and it fits, fits with extra room. Maybe using the stock intercooler in that fashion and in that location might not make any difference or much of a difference for the hassle. But, since I have to be down there to install the tank, lines and so forth I might as well give it a try.
Old Jul 27, 2011 | 05:49 PM
jmb614's Avatar
E55 AMG
+1 I think I saw one in an older thread whilst searching around one day
Old Jul 28, 2011 | 03:28 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
One annoying thing about my bigger I/C is that its prob 5x the weight of the OEM one... and thats empty so its not fluid volume.
I am not that convinced a bigger H/E is necesary over a OEM H/E if you running a decent rear tank setup.
Old Jul 28, 2011 | 11:55 AM
LOCO 05' E55's Avatar
P-Carro
Im I the only one running both the CODE 3 HE and stock unit??
I dont have a trunk tank so i had them hug each other in the front
Old Jul 28, 2011 | 02:21 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Are we talking
Intercoolers?
Or Heat Exchangers?
Old Jul 28, 2011 | 02:26 PM
I Like Soup's Avatar
2003 E55 AMG
Maybe so. I got the 7" core for the '03s so I only have the Code 3 HE unit that holds 80ozs...
Old Jul 28, 2011 | 02:48 PM
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
Originally Posted by Jakpro1
Are we talking
Intercoolers?
Or Heat Exchangers?
thats what i was wondering too as i thought the IC is under S/C as in the pic you posted and H/E is in front of car under ther bumper
Old Jul 28, 2011 | 06:50 PM
GT-ER's Avatar
2005 E55 AMG
Technically, an intercooler is a heat exchanger and a heat exchanger is an intercooler.
We are talking about the one that sits in the bumper.
Old Jul 29, 2011 | 04:06 AM
stevebez's Avatar
Techinically the "thing" in the bumper is a radiator, and the "thing" under the supercharger is an intercooler.
Old Jul 29, 2011 | 07:46 AM
Velociabstract's Avatar
SRT-6
I always think of it as a supercharger aftercooler myself. The heat exchanger's behind the bumper. I don't have room for 2 in my car unless I get real inventive.
Les
Old Aug 1, 2011 | 12:16 PM
gaspam's Avatar
i always thought of the heat exchanger as the heat exchanger that exchanges the heat from the hot coolant that is coming from the intercooler and then returns it to the intercooler :P
Old Aug 2, 2011 | 12:32 AM
GT-ER's Avatar
2005 E55 AMG
