Intercooler Pump you didn't know about
One the plate and mounting was not simple, and I was afraid it would be too fast for a HE with Bar and Plate design.
I think for those who have tube and fin HE's its a better solution for faster flowing pumps.
My understanding Bar and Plate tends to flow more rapidly than tube and fin and you loose the efficiency if the coolant flows too fast.
These new options sound like a good compromise between larger pumps and stock.
If this SLS pump works, I would buy it to replace my CM30. Only due to the fact it has the AMG logo.
We did just that, but the car is still down on power, so I need to start troubleshooting the problem Tuesday. I'm sure I will get it sorted out, when I start playing with STAR and back on the dyno to check boost and stuff.
But just an update, The pump is installed and I'm sure once we get the issue sorted out I will have some data for you guys. I thank dumb luck for letting me catch the problem before a CEL could pop up and about one street away from Dyno-Comp.
I'm sure a lot of us know that feeling of "WTF! where did my power go!"
http://news.renntechmercedes.com/201...mp-comparison/
I'm going to order a couple of these kits to see how they stack up against a $400 DIY set up (PLM H/E + Meziere W136)... When I am done testing, I will either give the kits away, or crush them
PS- Thanks for the Meziere Hooley.. Working well now that it is not sitting on my kitcjhen table
So on my car (2005 SL55) with a stock cooling system saw a max temp on the dyno of 131 degrees after installing the SLS AMG pump.
You guys tell me is this any good?
Anything over 120 and you will see timing being pulled, which is completly normal for stock or even modified cooling system.
I just got off the phone with Rich at Dyno-Comp. As I was leaving he was going to dyno an E55 with a rear mount cooling system, meziere pump and FF headers and a 180mm pulley. When I was leaving I asked if he would just look at the IAT's for a comparison. Because I had no idea if 131 degrees was good or not good.
The E55's IAT's topped out at 77C. That equals 170 degrees. I'm sure the rear mount cooler was not packed with ice. I even think the owner of that car is on this forum. Who that is, IDK?
My power was up slightly.
At the track I really shoot for 120 or less for a whole pass.
I remember Matt (one of the techs at Dyno-Comp) telling me the wiring was different. IIRC he said there were 2 power connections or 2 grounds. something of that nature.
Keep in mind I sell no pumps so I have no reason to hype this pump over any other for that matter. I just want a good pump that isn't loud on my car. In the end its just another option guys have when picking a pump for their car.
I just bought one and there are 4 pins on the pump. The MB wire diagram shows pin 1 as ground, pin 4 as constant power, and pin 3 as a PWM output from the control unit.
How did your guy eventually wire it up to work without using the PWM.
Thanks for the help, really looking forward to getting this pump working.
Todd
