Can battery control module failure cause batteries to drain??
Old Aug 14, 2011 | 09:37 PM
bobgodd's Avatar
2004 E55
I suspect that my battery control module (BCM) is bad, though I don't know how exactly to confirm it. I have ran through about 4 batteries in the 3 years that I've had the car and that seems way too high. Right now both batteries are WAY under voltage - 8v for the under-hood battery and 5v for the main battery. The main battery is about 6 months old. The alternator is roughly 2 years old; was replaced (which I am told includes voltage regulator) at a Mercedes dealer. The under-hood battery is also roughly 2 years old.
The reason I suspect the BCM is because there are 4 new part numbers since the original one was released with my car. The car is a 2004 and I have the original part number module, and when I called Mercedes to inquire, the parts guy told me that there were upgrades and that my part number was now obsolete. I have also read posts in this forum saying that the original design was defective...?
The car is a 2004 E55 and is about to turn 97 thousand miles. Any thoughts?? Thanks.
Old Aug 14, 2011 | 10:26 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
There are at least 4 software updates too.
https://mbworld.org/forums/1256180-post2.html
Is your car going in to sleep mode?
Old Aug 14, 2011 | 11:46 PM
bobgodd's Avatar
2004 E55
I saw that post this morning and I'm going to call a few dealerships tomorrow morning. I'm not sure what sleep mode is actually, but the car was driven yesterday, and I had to jump it today to get it to start.
What do you think are my odds at getting them to do the software update??
Old Aug 15, 2011 | 11:56 AM
bobgodd's Avatar
2004 E55
Ok just called the dealership and she said that service has already been performed on my car.
I wish there was a way to test the BCM to find out if it's faulty...
Old Aug 15, 2011 | 08:54 PM
Shifter's Avatar
E55, SL63, ML550
The BCM controls consumer shutoff and can give erroneous messages, but rarely if ever have I seen one actually cause a draw itself. You need to start with charged/good batteries, and then test for a draw-- car locked and asleep.
Old Aug 15, 2011 | 10:10 PM
bobgodd's Avatar
2004 E55
I was also under the impression that it dictates how the batteries - specifically the auxiliary battery - is charged. Is this not so?
Old Dec 23, 2012 | 12:57 PM
TUngpiyakul's Avatar
E320
I am having a similar problem with my 2004 E320 for about 6 months. I did a lot of investigation but still have not solved the problem:
1. Periodically drains battery at about 2.2 amps. I use a clamp on ammeter to measure this. Once occurred, it will continue to do so until the battery is either drained or disconnected for several hours. This started at the period of about 6 months to weekly and now every 2-3 days.
2. I replaced the battery, it did not fix it.
3. I had a service shop (not MB) disconnected every fuse one at a time. It did not stop the 2.2 amps drain.
4. If fully charged, it will start after 8 hours but with the convenient function disabled
5. I took it to MB shop twice when it was draining, but it stopped the drainage before the mechanics found the problem.
6. I am checking the drainage rate every day now and wait until it happens all the time before taking it to the MB shop again.
Does anyone have a suggestion?
Old Dec 23, 2012 | 02:04 PM
03'55AMG's Avatar
AMG
This thread is over one year old...
Old Dec 23, 2012 | 03:02 PM
E55AMGGG04's Avatar
04 w211 E55
I had my battery control module changed a couple years ago for about $2300 :/ at the dealer. I do know that it didn't kill my battery though. My original battery died further down the road and I had it replaced with a crappy battery because my car was stuck in the street and I went to strauss and bought whatever they had and that battery just died on me yesterday. Maybe the batteries your buying is as crappy as the one i had bought less than a year ago that is now completely shot
Old Dec 26, 2012 | 03:26 PM
E320
Thanks for the info. I was hoping that the BCM was your problem. I know that my problem is something draining the battery at the rate of 2.2 amps. I just don’t know what. When the ammeter indicates that is draining it, it will get weak in about 6 hours and die after 12 hours. I already spent about $400 but the problem is still there. It looks like the BCM is not hard to replace; I might just do it myself.
Old Dec 26, 2012 | 05:37 PM
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
$2300 to buy/change a battery control module? I know they are known as the stealership but I don't see how that is even possible they could rape you that bad. That would be like 15 hours labor or something crazy. The unit itself I just bought for $344 (not including shipping) new from GenuineMercedesparts.com and they are listed at $430 which I would assume is a dealer price. And then it is literally a less than 5 minute job to replace.
Also, I ended up not needing it since my voltage regulator was bad and fixed my low voltage problem (car would go from reading 14 volts to 11 and back and forth when it wanted). I am about to return the battery control module if I can unless someone wants to buy it for like $300 shipped.
Old Dec 26, 2012 | 06:03 PM
E55AMGGG04's Avatar
04 w211 E55
Yeah Im sure I have the receipt somewhere in here and I actually made a mistake. Alternator + BCM was $2300. My bad but still rape lol
Old Dec 26, 2012 | 06:18 PM
Celicasaur's Avatar
W212 - E63 AMG
Exact same problem on my car! The mysterious 'flat-out' happens every 5-6 weeks and has been doing so since August this year. I've fitted a brand new battery and aux battery module (the newer Siemens unit) last week and the week before that I replace the aux battery for a new Bosch unit and also replaced the alternator regulator. What I can confirm is that my alternator brush packs were quite worn and as a result my main battery charging power has gone up to 14.2v with the engine running (since August it's been 13.8), my cold start crank is cleaner and quicker, my SBC stop problems are solved and I no longer have that annoying red battery warning message. I'm not sure if it'll stop the weird problem though...I hope it does. I guess we'll know for sure in another 4-5 weeks...
Old Dec 26, 2012 | 07:44 PM
E320
If it is the same problem as mine, the frequency will get shorter. In my case, the time from the first to second occurrence is about a year. Now it is every 2 -5 days of driving. It acted like something got started and never stopped even after the key has been taken out. If your problem continues and you want to deal with it (using the red neck method), let me know I will post the detail. Mine happens every 3 – 7 days of driving, but I never need a jump start since I implement this (somewhat hilarious method). It needs about $100 worth of parts, though.
Old Dec 26, 2012 | 07:59 PM
urbamworm's Avatar
I hope this "redneck"" method doesn't include a battery cutout switch that you turn on and off every time you use the car lol.
Old Dec 26, 2012 | 09:34 PM
novae500's Avatar
W211
Similar to me. Replaced the volt regulator, new aux battery, front battery relay and battery control module in trunk. No more low battery conv functions disabled or the red battery code . I replaced ez h part one by one until the codes cleared themselves. Car now sits at 14.4 when running. .
Old Dec 26, 2012 | 10:51 PM
Celicasaur's Avatar
W212 - E63 AMG
The people demand it!
Old Dec 27, 2012 | 09:59 AM
E320
Here is what I did:
1. Extend the negative terminal out so that it can be accessed when the trunk is open. I use another battery terminal cable for this.
2. Extend the positive terminal out so that it can be accessed when the trunk is open. The cable here has an insulated cap at the end so that it can be open to charge the battery.
3. Every night after driving is done, I check the battery drainage using a clamp-on ammeter on the negative terminal (after the car is in sleep mode).
4. The first few times it was draining, I pulled every fuse but the drainage never stopped. I charge the battery overnight using a trickle charger. It went on for days and never stopped. I took it to the MB service but it stopped before they found the problem.
5. Currently after I detect the drainage, I charge the battery overnight first. If it does not stop, I disconnect the battery the next evening. The problem went away for 3 – 5 days after the battery disconnection.
I will wait until it happens more frequently before I take it to the shop. I think I will duplicate what NOVAE500 did to see if it will fix my problem.
Old Dec 27, 2012 | 04:34 PM
Celicasaur's Avatar
W212 - E63 AMG
Now that's dedication!
Old Dec 27, 2012 | 05:25 PM
E320
I consumed a lot of beer thinking and working on this. I did not like working on the car, but I did enjoy the BEER!
Old Dec 27, 2012 | 07:09 PM
novae500's Avatar
W211
Some people find out that its the audio gateway that is the drain ; for me it was bcm and battery relay
Old Feb 10, 2014 | 07:15 PM
E55AMG05's Avatar
2005 E55 AMG
You see that's BS there is no relay for the F***KIN AUX there is only a BCM that controls all OK!!! Srry I have been going through this prob since OCT. I am losing my mind. I can't stand it every1 asks about my AMG and I have to come up with something to lie and make a excuse. If there is a aux relay PLZ PLZ GIVE ME D PART NUMBER
Old Feb 10, 2014 | 08:09 PM
Joncl's Avatar
E55
A0025423819
Old Feb 10, 2014 | 08:42 PM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
It seems like you have had a lot of different problems with your E... Was it a flood car or something?
Old Feb 10, 2014 | 10:19 PM
E55AMG05's Avatar
2005 E55 AMG
No not at all why r u saying that what the hell I just want the part number PLZ
