3, 4, 6 Injectors open circuit problem, solution?
These 2 days, I go WOT on the 2nd gear then to the 3rd gear reaching speed of 180 km/hr, after finishing the run, I noticed drop in power and sound of mis fire engine, even the S/C would go off (no warning on screen but i can notice the power and also no engagement of clutch). I got check engine light too.
I pulled out my scanner and I got injector 6 open circuit and also cylinder 6 mis fire, I tried to check what's going on, could not figure it out, later on when the car got cold,I started the car but the same symptoms again. Then i pushed and played a little bit on injector 6 plug and plug's wire, started the car back and it is fine.
While driving the car and going WOT before this incident, I sometimes got injector 3 or 4 open circuit but not a lot while i get injector 6 so often.
Anyone has experienced similar issues? I have the 550 cc red injectors.
Can someone give me any idea? solution?
I would not go WOT without fixing this issue....
I personally had 1 injector go bad (reds) and had to send it back after the car misfired and started to smoke. I pulled the plenum and noticed about 2" of fuel on top of the valve! Not good! Testing showed a bad injector, and it was replaced under warranty quickly.
It also might take the car a few minutes to see the change and start running right, I know mine did!
