Lookie what I found...fuel injector content.
Some what the same type of stuff goes on in other platforms for people all talking about fueling, and example I can give personally was everyone said the stock lines and returnless system couldn't work for 400whp in my Audi. People got on the train and all started changing the systems to bigger lines, return systems, etc until someone simply put significantly larger injectors in with a better fuel pump and ran 500whp perfectly, and now that is how everyone else is doing it. That is the same thing going on here where people "think" you need an altered rail because a car or two put an altered rail on WITH bigger injectors and then the car worked. But the big change is the injectors which as shown from multiple people who only have bigger injectors and have a perfect a/f, good running car and injectors that are happy at a low duty cycle.
And sometimes the internet is hard to convey things, I am not trying to be confrontational just to be clear, just put out what I have experienced as well as others in the same boat as me. Sometimes you don't need more, a simple change does the trick.
On a side not, had a little run in with a C5 Z06 last night, LS6 bored 10 over, trickflow heads, cam, headers exhaust. Said he dynoed 430whp, he was shocked that I kept up and said nobody has been able to yet. He jumped a car in front when we took off from like 50 partly because I was quickly downshifting as he was honking and then we stayed dead even up to around 140 maybe slightly higher. I was pretty happy especially with it being so hot where I am.
me too...
I had reviewed the Five-O injectors, and the company has a great reputation. If you call them, they will talk injectors all day. They will even provide opinions which might send you away from their product. That is just the way they are.
With that said, I think the injectors in question are awesome, but I opted for the dual spray pattern provided by the TTM injectors. I suppose someone could do some in depth dyno testing, but the bottom line:
A larger, properly scaled injector with a closed loop fuel rail will yield safety that the stock configuration (even with bigger injectors) can NOT accomplish.
As I have said before, I do not have any association with Bruce at TTM other than being a retail customer. I just want anyone who has the same passion I have for these cars to not have to suffer through the pain associated with a major failure (I.E #8)
Bruce- GB the rail already so I can miss another deal!!!
Weeee....
