E55 dyno results
E55 dyno results
Hey
Just thought I will let you guys know the mods I have done in stages.
First stage
190mm pulley
long tube headers eurocharged
3inch straight through system
Rear eisenmann boxes
512.9 rwhp
807.5 ft-lbs to the wheels
564.2 to the engine
888.3 ft-ibs to the engine.
Are these the figures that you guys are getting with these mods?
Thanks acid
First stage
190mm pulley
512.9 rwhp
564.2 to the engine
Thanks acid
PLATINUM SPONSOR
The HP is in line but Torque is way to high for our engines. Should be 630 range.
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Well that's what I thought but i will get the car mapped in the next few days, as these readings where without a custom map and just a generic map.
Then I will put the cams in and do a dyno
Then the 82tb and a dyno and injectors!
See what the diff is with each mod.
Acid
Acid
Yeah. I got EC cooler and cm 30 pump aswell. I just need to sort out the spilt cooling to finish it.
I will be 0-60 mph runs on Sunday here in the UK will let you know the results but mine is a wagon and I don't have LSD lol.
Acid
Acid
Nice, once you put an 82 TB it will open up that top end. Crazy power!
Well. I already got the cams and tb but I have sent my spare heads off to get ported and polished so when they come I will put one part a time in and dyno them and see what make more power plus I got injectors from Eurocharged aswell.
The 190 pulley is good may need a few more lol
Sounds about right. I'm between 512-516rwhp on different DynoJets with my mods. The key is to be able to back up those numbers with some timed runs. I don't think 0-60 would be a good test for that amount of power and torque. You should try 60-130 if you have a good road to run it, or take her to a dragstrip.
Let's hope skratch is right or you'll need a transmission upgrade.
^ No ****...
unless I am at the track, the longest I can hold down the throttle is about 2 seconds. I either run out of road, have a car in front of me, or get to "Felony Wreckless"..
Converting 585-590 pound foot to Newton-meter will equal 800!
Hes making Nice power, TB , a nice cooling setup and Open exhaust Will make this car haul some assssss
Nice one Acid, i see the motor is progressing well, catchup at TRAX on Sunday, lets try and get some pis up for the US guys
PLATINUM SPONSOR
Acid, Be very cautious with who and how they port your AMG heads. It takes a lot of flow test and R&D to get these heads to be superstars! Many of the traditional porting tricks will loose flow on these AMG heads. Unless your ported flow test everything, keeps the velocity up and spends the time to build all the test fixtures, I would not let them touch them! Even standard chamber work can hurt your power on these heads. Be carefull bro!
Sounds like you are building Godzilla!!!
__________________
www.ultimatepd.com
www.ultimatepd.com
Before the heads go on I will get a flow test done and pass the results to you and see what you think as this is new for Us in the UK , they are being done by a professional race team so I will let you know the results
I hope she a monster once finished , I am trying to be the first E55 in the UK to get into the 10s lol. And I hope I will be the first E55 wagon to get into the 10s in the US. Or has someone already done it?
Ideal results would be 580 to 600 rwhp
Acid
Yeah we trying to get as fast as our brothers in the US lol.
You guy do some mad mods and make big power we are not far behind................
We will put some pics we should have a good turn out at trax
Acid
PLATINUM SPONSOR
Hey
Before the heads go on I will get a flow test done and pass the results to you and see what you think as this is new for Us in the UK , they are being done by a professional race team so I will let you know the results![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Acid
Acid
__________________
www.ultimatepd.com
www.ultimatepd.com
