Got some exra $ and want more ponies...
Old Sep 23, 2011 | 01:43 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Originally Posted by TheVazha
Please PM me your best price for the airbox shipped to 90048...
can do, but I would do tb or longs before the airbox. Better hp for your $
let me know...
Old Sep 23, 2011 | 02:39 PM
TheVazha's Avatar
W213 E63
let me know...
If I can get a used TB and your airbox that's got to make more power then some LT's right?
Old Sep 23, 2011 | 02:42 PM
skratch77's Avatar
2005 E55
Do you have all the parts needed for install? If yes, please PM me your pay pal info...
you will need a sc inlet and y pipes and the gaskets to go with the kit.
All I have is a spare mb 80mm tb,ill do it for 300 shipped
Old Sep 23, 2011 | 04:34 PM
ArmoE55's Avatar
2006 E55
I don't see any TB + airbox combo making as much power as long tubes alone ... those LTs make some SERIOUS power.
Old Sep 23, 2011 | 05:38 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
you guys are all comparing gains from lt's against stock exhaust which vazha isn't running...
Old Sep 23, 2011 | 05:50 PM
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
ditching the shorties and picking up LTH still seems like a much better HP pickup per $ spent idea unless he is doesnt want to give up the shorties.
he could prob even sell the shorties and reduce his all-in LTH cost
Old Sep 23, 2011 | 06:27 PM
  #32
alextaylor29's Avatar
2004 E55 AMG
If it were me I'd to the 180mm and ECU tune. This should get you +60-70 RWHP easily and collectively they're much cheaper than full headers which will give you +60HP.
To me this sort of discussion is always a dollar per HP thing. Pulley plus tune = $1,500 for 60-70HP. Full headers with install, $3,500 for 70HP. So $2K more for the same HP.
Here's the sequence approach I took:
1. K&N's
2. Johnson Pump
3. ECU Tune Stage 1
3. 180mm pulley
4. ECU tune stage 2
5. LTH with full cat-back replacement
6. ECU tune stage 3
This maximized my dollar and HP gains. All I have to do now is air scoops and python tubes.
Alex
Old Sep 23, 2011 | 06:35 PM
  #33
AMG_RL's Avatar
E55 AMG, 72' Toyota Carina, 63' Ford F100, 72' Mercedes 250c, 15' Harley Davidson Softail
If you bothered to read the first post you wouldve known the op already has a pulley + tune. My $$ would go to LTH as others mentioned
Old Sep 23, 2011 | 06:37 PM
  #34
2004 E55 AMG
Got it sorry, read it quickly and thought those were the mods he was considering, not what he had already.
Do headers then!
Alex
Old Sep 25, 2011 | 04:03 PM
  #35
cahiil55k's Avatar
I like the throttle response part. I let my Ruski body shop guy drive my ride and he was blown away. He DID say however that I should look into a sprint booster because you really have to let her rev up for that "pin you in the back of your seat" feeling. Will a TB improve the low end?
I've read that the TB will increase hp and torque throughout the rpm range. I've never tested just the TB upgrade alone, but my dyno plots show increases across the rpm range when I went from stock to stage 3, and the lines were almost parallel with my stock dyno. Regarding the sprint booster, I don't have one but I think it may be too harsh for our LA traffic unless you have a very well-trained foot.
Old Sep 25, 2011 | 04:30 PM
  #36
TheVazha's Avatar
W213 E63
I had a chance to do some more homework and spoke to a couple forum Gods and I think the TB mod is way too technical for me! lol
I'm just a humble kid and it sounds like unless you get the correct TB, and install correctly, you can run into problems?
The pulley concept I understand. Larger pulley more boost. The headers I understand as well. Combined, let the EC geniuses tune it and you go fast. I don't think I can source a proper TB and install without running into some reported issues with the mod...
Does anyone with a solid reputation here have a complete working legitimate TB + parts for sale?
Also, I noticed some of you guys are referring to TB's as OEM parts. Does the 82mm TB come on other MBZ cars? Are the "OEM" parts better then aftermarket parts, and what car in the MBZ line up would have the TB that I want?
Thanks guys for all the advice!!
Old Sep 25, 2011 | 05:44 PM
  #37
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Pretty sure you would want to go with the TB off the 550 cars.
Old Sep 26, 2011 | 12:52 PM
  #38
TheVazha's Avatar
W213 E63
Guys can anyone confirm what MBZ has the TB I want?
Old Sep 26, 2011 | 05:25 PM
  #39
Silverr1's Avatar
04' E55K
A quick shameless plug :-)
https://mbworld.org/forums/engine-pe...y-82mm-tb.html
Old Sep 26, 2011 | 05:30 PM
  #40
bnzuovr's Avatar
2004 W211 E55K, GL550
let me know...
Jerry does T.B Cause it to kick any trouble codes i have heard from a few diffrent sources that the T.B will cause light to come on is this true?
Old Sep 26, 2011 | 06:39 PM
  #41
BenzoBoi's Avatar
Super Moderator
W221
Long tube headers and a 82MM TB.
That's what I would do...
Old Sep 26, 2011 | 09:20 PM
  #42
loungn14's Avatar
SPONSOR
yup, if they are improperly installed or have a vacuum leak. (or don't do the tb reset that is included with our instructions and on the forum)
Old Sep 27, 2011 | 12:16 AM
  #43
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
Eurocharged LTH are nice quality and well worth the $$ but be aware that you should cater extra $$ for mid section exhaust. I was planning on doing it in stages ... headers then exhaust later .. but that isn't really an option with these headers.
I need to get the TB reset instructions ... I didn't get any from you guys. I'll search the forums too. Also read about some bucking issue some folks are experiencing ... any comments on this?
Old Sep 27, 2011 | 09:26 AM
  #44
loungn14's Avatar
SPONSOR
https://mbworld.org/forums/w211-amg/...ode-p0507.html
bucking, is either a vacuum leak or the tb needs to be reset.
