S/C shutting down
Old Sep 23, 2011 | 03:53 AM
cwmateiuc's Avatar
2006 E55 AMG
S/C shutting down
I'm so confused, my car is stock other than a Johnson pump and a bigger heat exchanger. Yet, if I do one short full throttle run, my S/C almost instantly shuts off, my coolant temps are actually nice and low... so I'm confused why it's doing that.
If I let the car idle for a few minutes and get in it.. no S/C until I cruise for a bit and suck in some cool air, then, if I get on it, even for a sec, no S/C after that for a little bit.....
SO CONFUSED!
Old Sep 23, 2011 | 07:03 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
costel what are your IATs.
Old Sep 23, 2011 | 09:06 AM
johnng117's Avatar
2002 C32 AMG
My car is the same right now, just ordered a new pump. But the current pump is only 6months old.
How do you measure your IAT?
Old Sep 23, 2011 | 09:07 AM
chawkins2001's Avatar
2006 E55 AMG
Yes, IATS and what is the mileage on your car? Johnson pumps are also known for premature failure. Did it come on the car or did you install it?
Old Sep 23, 2011 | 09:14 AM
johnng117's Avatar
2002 C32 AMG
I installed the latest Bosch six months ago. My car is a 2002
Old Sep 23, 2011 | 09:55 AM
cwmateiuc's Avatar
2006 E55 AMG
The car is a 2006 with 53k and I installed the pump my self last week. How do I check my IAT's?
Old Sep 23, 2011 | 10:03 AM
shardul's Avatar
get a OBD2 scanner and you can view the IATs under live data
Old Sep 23, 2011 | 01:45 PM
cwmateiuc's Avatar
2006 E55 AMG
What are normal numbers?
Old Sep 23, 2011 | 02:01 PM
shardul's Avatar
if you are in the 199 range at WOT then you know the s/c will be shut off
Old Sep 23, 2011 | 08:23 PM
nicco's Avatar
E55 AMG
Maybe you have air in the system. Did you bleed your system until it got rid of all the bubbles when you installed your HE and pump?
Old Sep 23, 2011 | 08:50 PM
cwmateiuc's Avatar
2006 E55 AMG
I had it bleeding for three hours.. Then it also worked out a few bubbles.
Old Sep 23, 2011 | 09:07 PM
nicco's Avatar
E55 AMG
Three hours wire that ****er to continues on. Runna a data logger and post your IATs
Old Sep 24, 2011 | 04:13 PM
TopGun32's Avatar
bleeding needs to been done right. There is a DIY posted, for your search.
You can't just let the car run and think the bubbles would come up to the coolant reservoir.
How is your ambient sensor? and also buy a cheap OBD2 scanner and measure your IAT's...
S/C shut down with out CEL is rare, usually is due to air intake temps.
If you have CEL, checks your plugs and wires first.
