damn these pumps are junk!!!
So for the life of me I cant figure out why my car is sometimes fast at the track and sometimes slow even on a cool down.
went to bleed the car and nothing came out of the nipple with the pump on.
Is there something Im missing? there should be fluid coming out right.
2005 E55 AMG
Did you pinch the return line? The one closest to the SBC pump? It makes things MUCH easier.Also, make sure the engine is at normal operating temperature as it seems to make things easier as well.
I just got it to flow but the water was not moving that fast and there wasnt a lot of volume coming out the hose I used.
I didnt pinch the return line but at least this morning I got it to flow some water
quick question.Its been like almost a week and my stupid car has not passed evap rediness.What is the procedure to make the car pass that test?
no codes thrown and everything else is ok
just took it for a ride and ran into a brand new black on black sl65 BLACK SERIES.Its the 3rd time I saw the old guy driving it and I should of turned around as he pulled into dunkins to check it out.
Now I know where he goes before work so ill try to go to that same dunkins to try to run into him again.
Im sitting about 17-23 above ambient and it drops down fast after I get on it.Will see how I do at the track tonight,no time to really bleed it before work
2005 E55 AMG
2003 E55 & 2014 GL550
Than basically just drive her around on the highway between 55-60 (yeah I know...near impossible) but it has to be done.
Just set the cruise and it should set after awhile.
Fuel tank is the biggest reason why some guys never setup.
Gtr i did bleed it but i didnt have time to get under the car to pinch the return line.
On the evap i didnt know we have to have a certain amount of gas in there as i keep it low sonce im taking her to the track.
Its been more than a week as i reset the ecu when i dynd the car.
05 White Pano E55, Cadillac CTS-V
You pinch the line right below the nipple where you hook the other hose up to bleed it. Do it right from the top, no need to get under car. You can see the vice grips in my video I linked on the line right below the clear hose I have connected.
