E55 vs S55 Air Intake snorkel
1 Post
2016 E63 s63 (sold),1986 Buick Grand National (sold)2014 ML63
I recently read a post that was pretty interesting- it said:
"My only modifications, which boosted the power from 469hp to approx 505hp, was to swap in the SL55 air intake snorkel and add K&N air filters. The far more expensive SL55 (using the same engine) was rated at 493hp and Mercedes claimed that a more restrictive exhaust system cut the power in the E55 but the true story was that the decrease in power was due to a $5 plastic restrictor in the intake system which took less than 10 minutes to swap out. The K&N filters provided about 12hp too."
The post can be located here:
http://www.derekspratt.com/HTML/Auto...cedes_E55.html
Seems pretty easy...any thoughts? And if so, where do I grab an SL55 air intake snorkel?
All thoughts and opinions are welcome!
Super Moderator
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
The E55's were understated to justify the price hike for the higher models. Many of the E55 guys that have gone to the dyno (including myself) have proved that they all push the same amount of power as the S, SL, and CL 55's.
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
Some of the higher powered E55 beasts are running the much bigger CF tubes that put in even more air. I'm pretty sure that adding the snorkel from the SL55 won't hurt and I could see the K&N's giving him some power, but just those two mods did not give him a 36hp increase.
the e's driver's side snorkel is smaller but changing it out doesn't address the fact that the inlet pass at the radiator (where the snorkel attaches) is also smaller so IMHO there's not much to be gained. with that said, for $7 from the dealer it's a no brainer to do it anyways.
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
The original E55 tube on the left side has close to a 50% restriction in the diameter (Go figure). Just replace it with a right side tube.
2005 E55 AMG
LOL...I love how people pretend to even have a clue of what they are talking about. So replacing the snorkel and dropping in K&N filters gave him 36hp?
Anyways, I doubt it really makes a difference. One side may be smaller than the other but both of them together are HUGE are flow more than enough.
Anyone that believes that the "Restriction" in the snorkels kills horsepower need to go back and learn about a little thing called Pressure ratios and while they are at it some basic aerodynamics
OK, we know that the pressure ratio of a compressor is defined as the absolute outlet pressure divided by the absolute inlet pressure. How are you applying PR's in this instance? And as for aerodynamics, are you referring to Bernoulli's Principle or a sonic venturi effect?
2005 E55 AMG
It's the same thing, there is virtually no pressure loss in those intake pipes.
after all, these are just gas powered air-pumps
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
1 Post
Nothing other than seat of the pants, but the K&N mod you can certainly feel. I did it before the end of summer.
I heard the K&N filters are okay by most manufacturers, provided they are properly maintained. Any other info?
Yacht master, that is sick mpg! I haven't quite gotten there...
1 Post
...and this seems to make sense if for no other reason but to balance things out....
contact your Mercedes dealer and for about $12 bucks you can order the larger tube and it fits right in (p/n# A 1130942182)..
