FML. Airmatic failure.
Old Oct 2, 2011 | 09:16 PM
justinwrock's Avatar
Ducati
FML! Noticed that the 55 was sitting pretty low while I was doing the brakes on my sisters SLK. Did not think anything of it, as the driveway has an odd angle...
On my way home, I ran over a manhole cover and the front left corner went THUD. Pulled over at a gas station, and listened for the compressor after hitting the button for raise mode.... Nothing.
So far - I have replaced the relay and fuse, with no success. Being at a crossroad, what do I do? Replace the compressor, or swap coilovers on?
Old Oct 2, 2011 | 09:48 PM
CityOfAngels's Avatar
2006 E55 AMG
Do you have a warranty?
Old Oct 2, 2011 | 09:51 PM
desired_speeds's Avatar
2007 SL55 AMG
wait so only one end of the car collapsed and the compressor isn't running?
Old Oct 2, 2011 | 09:54 PM
Pushing_Tin's Avatar
2007 E63
Just curious how many miles you have?
Old Oct 2, 2011 | 10:02 PM
Ducati
Negative Ghostrider.
The whole car is sitting lower than it normally does. I cannot hear the compressor running, and the car is not rising.
132k.
Old Oct 2, 2011 | 10:37 PM
BenzoBoi's Avatar
Super Moderator
W221
I would say go with the coil-over conversion.
Old Oct 2, 2011 | 11:08 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Old Oct 3, 2011 | 05:20 AM
2007 SL55 AMG
probably the pump itself then
Old Oct 3, 2011 | 02:30 PM
Ducati
Ordered the coilovers to convert it!
Also found a used airmatic compressor locally for $100. I am going to pick it up/install it so that I can drive the car. I have a week off in November and will do the coilover conversion then.
Old Oct 3, 2011 | 03:07 PM
2007 SL55 AMG
daaaang
Old Oct 13, 2011 | 02:12 PM
spinn's Avatar
2004 E500
what's the estimated cost to do the conversion? You doing it all yourself?
Old Oct 13, 2011 | 02:47 PM
BenzoBoi's Avatar
Super Moderator
W221
Sounds good!
Old Oct 13, 2011 | 05:24 PM
Alps's Avatar
E63s s213 2019 ,SOLD E63 Weistec, E55, C36
worth keeping a spare at that price!
