E55 nitrous setup
Old Oct 13, 2011 | 04:30 PM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Originally Posted by E55Bullet
First e55 to hit tens was using the spray. He had a pretty elaborate setup. There is also rumors of a full bolt on car with over 150 shot "rumors" but it's supposed to be the fastest.
Understand it was/is a 9 second car....
Old Oct 13, 2011 | 06:15 PM
E55Bullet's Avatar
2008 ML63 2009 SL63 2010 Alpha 7 GTR
I've heard that too! Damn rumors!
Old Oct 13, 2011 | 06:27 PM
Nino S's Avatar
2005 E55 AMG
I will never run nitrous on my E55. I have killed 3 motors in my 91 Mustang that is a full drag set up and it is just too expensive. I was pissed off when I blew a little 302 that cost nost even $3000 to rebuild, I cant imagine doing that to my 55. If you decide to go that route best of luck to you I just think there are too many other ways to make power with these cars other then a baby bottle.
Old Oct 13, 2011 | 09:45 PM
03'55AMG's Avatar
AMG
Would a little 50 wet shot be good? Just to cool things down a bit on those hot and humid summer days?
Old Oct 13, 2011 | 10:07 PM
guysandiego's Avatar
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
5-hp per cylinder is really nothing -- as long as your timing is not really advanced -- and no engine problems --- the engine should be able to handle it
Old Oct 13, 2011 | 11:34 PM
lowprofile's Avatar
E55
The biggest issue I have witnessed with N2O kits is not with the N2O itself, but the owners. Typically they are looking for cheap horsepower and are on a budget. They run with no wideband or fuel pressure gauge and have no game plan for user error, faulty solenoids, wiring issue, etc.
Old Oct 13, 2011 | 11:38 PM
  #32
Ali_E55's Avatar
C218 CLS63TT PP Edition1, W213 E63S
it is possible and some guys did it here in UAE without a fail.
some did it manual and some had it controlled by a device to spray and it changes the amount of spraying depending on gear or RPM/Speed. ( not exactly sure ).
their cars were way too fast.
Old Oct 14, 2011 | 08:00 PM
  #33
reeper6's Avatar
2004 MB E55
one guy I know that ran 10.7 Albert (aka rflow306) sprayed a "lil" lol talk with him!
Old Oct 14, 2011 | 08:58 PM
  #34
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
But Albert (an engineer) is car savvy, he was way ahead of the curve back in 2005 (when a short block was $45,000.00) he pretty much knew what he was doing. So I find it hard to encourage someone that needs help finding the fuel & pressure. Just Saying there are better first mods.
Old Oct 14, 2011 | 10:14 PM
  #35
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Old May 13, 2013 | 04:09 AM
  #36
cwmateiuc's Avatar
2006 E55 AMG
I guess I should have clarified. I was asking "where" to get the fuel from in a sense of what's the best location, to save myself the trouble.
In E46 M3's, there is a product that nitrous express makes that pretty much "snaps and screws" into the fuel line underneath the car somewhere (it's been a while, I forget). And I was asking about fuel pressure because that has a bit to do with a wet shot (doesn't mean that I would not verify or run a fuel pressure gauge)
And, for the other posts... I was planning on using a wide-band, RPM window switch and a lean shut-down switch.
But didn't do it and not going to do it anyway.
Old May 13, 2013 | 04:22 AM
  #37
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
Damn, talk about a little late on a response.
In E46 M3's, there is a product that nitrous express makes that pretty much "snaps and screws" into the fuel line underneath the car somewhere (it's been a while, I forget). And I was asking about fuel pressure because that has a bit to do with a wet shot.
Old May 13, 2013 | 04:27 AM
  #38
cwmateiuc's Avatar
2006 E55 AMG
Yeah, I just came across the thread lol figured I'd respond.
A lot of people are afraid of nitrous because of other people no knowing exactly what they are doing.
It's "unsafe" because it's easy to mess up. People think that you can just put a nozzle into your intake and press a button and go.
It's not much different than a S/C or turbo, it increases cylinder pressure, just does it in a different way.
Just a substitute for the forced air you in putting into your motor with a S/C or Turbo motor... still allowing you to burn more fuel because there is more oxygen available.
And the torque from nitrous....
So someone running a 205mm or even 190mm bottom pulley.... doesn't have much room to talk.
Old May 13, 2013 | 10:22 AM
  #39
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
I'm still fairly new to the 55K, but not new to nitrous... I'll figure it out
Go with bolts on for the 10`s. Pulley`s, tune, long tubes, cooling mods, tires , few diet mods , larger TB, then find a good track and cool weather and you are there. Stock pistons, and n20 are not a good combo.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old May 13, 2013 | 10:24 AM
  #40
PLATINUM SPONSOR
2003 CL55
Go with bolt ons for the 10`s. Pulley`s, long tubes, cooling mods, diet mods, tires , good teack and cool weather for the 10`s. N20 and stock pistons have not been a very good combo.
__________________
www.ultimatepd.com
Old May 13, 2013 | 11:09 AM
  #41
RedBullJnky's Avatar
you to Hate
The CL55 at JSBenz has a 172, kleeman headers, and a 200 shot.
Old May 13, 2013 | 11:30 AM
  #42
99lightning's Avatar
99 ford lightning
nitrous is in no way worse then taking a pullied supercharged car and hammering on it in hot weather.
