E55 nitrous setup
Old Oct 12, 2011 | 12:32 PM
cwmateiuc's Avatar
2006 E55 AMG
E55 nitrous setup
Hi, I want to do a few things to my car, one of them being nitrous.
I did a few searches and didn't find what I was looking for still.. Does anyone know where I can read about someones setup? Maybe with some installed pictures?
So I'm assuming you would typically run a single nozzle system.. where would I tap for fuel and what is the stock fuel pressure?
Old Oct 12, 2011 | 01:20 PM
Robert AMG's Avatar
Cls63 & C32
i can help you here, a friend of mine has an e55 with 175mm pulley and tune, he installed a wet nitrous universal kit 100 shot, on the second run his engine blow, he paid 5k for a used one, don't play with nitrous especially if the car is modded.
Old Oct 12, 2011 | 04:52 PM
BRABUS786's Avatar
Stage 3 63
Hi
Nitrous is fine used it on modded cars. But you have to be careful not to use too much and use a controller
Acid
Old Oct 12, 2011 | 05:00 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Get a pulleys and tune and you will be happy
Old Oct 12, 2011 | 05:08 PM
cwmateiuc's Avatar
2006 E55 AMG
Well I'm pretty familiar with nitrous, just not with the specifics on this particular car.. I want to be in the 10's lol.. and obviously I will make other modifications, also.
Old Oct 12, 2011 | 05:37 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
This is not a small block chevy, AMG pistons are hard to find, and when one has a land failure, the cylinder wall (alum) will be damaged. Then what? Sleve one cyl or all 8?
All new pistons? You do know our pistons are cast, don't you?
Old Oct 12, 2011 | 05:40 PM
cwmateiuc's Avatar
2006 E55 AMG
Yes I do know the pistons are cast and the block is aluminum... yet still I see people spraying e55's all the time with success.
Old Oct 12, 2011 | 06:25 PM
Sher Judge's Avatar
2017 991.2 Turbo PDK 2017 C63S Coupe Ceramic Brakes 2015 CLS63S AMG Full House
The letter "N" for Nitrous, also means "N" for No.
As recommended by Shardul and boy does he know the "E55K"
(Pulleys & Tunes) with lots of cooling, just ask him.
Old Oct 12, 2011 | 06:33 PM
cwmateiuc's Avatar
2006 E55 AMG
I'm still fairly new to the 55K, but not new to nitrous... I'll figure it out
Old Oct 12, 2011 | 07:08 PM
Sher Judge's Avatar
Lets know what happens.
Old Oct 12, 2011 | 11:19 PM
RedBullJnky's Avatar
you to Hate
Shardul is the man! Take some advice. You can reach tens with other mods without Nitrous.
Old Oct 12, 2011 | 11:42 PM
GHAZAN's Avatar
MBUSA
You only live once...spray away
Old Oct 12, 2011 | 11:56 PM
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
Aren't the only guys who have made it in the 10s spraying? The member Loco comes to mind where he said he had to spray in order to break in to the 10s on top of meth injection, headers, pulley, tune etc.
Old Oct 13, 2011 | 12:02 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
no way...there are plenty of cars with only moderate bolt-ons that can run 10's with good track conditions.
Old Oct 13, 2011 | 12:18 AM
adianaty's Avatar
E55, CTS-V Wagon, Duc 1098R
I was thinking of a small system instead of meth and came to some basic conclusions that I haven't vetted so take them for what it's worth. First for a wet system I was planning on installing after the IAT sensor. Reason being that if it's before the ECU will add timing due to the lower temp and you will have a grenade on your hands. That means either one nozzle on the splitter after the IAT sensor that feeds the surge tanks or two one on each feed to the surge tanks. I've been told fuel pressure is 4 bars (60 psi) but would verify that before finalizing the system. You can pick up the fuel from the driver side fire wall (it's essentially a -6 steel braide) or from the fuel rail which has a -6 shraider valve. Of course the valve will need to be removed which should be pretty simple. I was also thinking of getting a tune that already took a couple of degrees of timing out just to be safe.
I ultimately went the mod route with meth first but still have a small system that I am still debating to put on.
Old Oct 13, 2011 | 12:41 AM
lowprofile's Avatar
E55
That's a big Negative! No spray on Loco's E55.
Old Oct 13, 2011 | 01:11 AM
urbamworm's Avatar
I remember seeing a thread titled saying he sprayed but just found it and he was just using nitrous to spray off the engine and parts to make it cold on top of it being 40 degrees outside! Those guys get serious too with skinny front tires and nice little light wheels in back with some drag radials.
Old Oct 13, 2011 | 03:35 AM
Hyperlite's Avatar
2005 E55 AMG
imo nitrous = cop-out/cheating
Old Oct 13, 2011 | 07:38 AM
Then ask the people you "see spraying all the time with success".
Old Oct 13, 2011 | 09:16 AM
KLR CLS's Avatar
CLS63 PP
Fuel inlet is on the driver side of the fuel rail. you would need to do a "t" fitting there to tap. One thing to keep in mind as these AMG's run much higher fuel pressure so fuel jetting will be off. As for nozzel jet locations I would tap each surge tank and run 2 nozzels feeding each bank. Don't tap before the IAT as it'll let the engine run more timing which I am sure you know is bad with N2O.
Old Oct 13, 2011 | 11:18 AM
TTMotorsports's Avatar
Whatever we're tuning!
Name:  TTM M113K dual nozzle nitrous system.JPG
Old Oct 13, 2011 | 11:19 AM
chawkins2001's Avatar
2006 E55 AMG
I believe this is unknown terriotory for the majority of E55 owners so they are very skeptical about running it. If you run a small shot, and have it setup safely within the correct window of the rpm range, you should be ok.
With that been said, do you research, speak to the seasoned tuners for their input, and go for it mang
Old Oct 13, 2011 | 02:49 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
One of the first guys to break 10s with the juice tapped fuel right off the Schrader valve on passenger front of engine. Literally plugged right into the universal wet kit he purchased.
Don't know more than that so least that gets you in the right direction....
Lots of old posts on the junk so use that search tool.
Old Oct 13, 2011 | 03:58 PM
E55Bullet's Avatar
2008 ML63 2009 SL63 2010 Alpha 7 GTR
First e55 to hit tens was using the spray. He had a pretty elaborate setup. There is also rumors of a full bolt on car with over 150 shot "rumors" but it's supposed to be the fastest.
Old Oct 13, 2011 | 04:05 PM
guysandiego's Avatar
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
one day - i would like to throw a small shot on it -- like a 25-dryshot - or 50-wet
