installed a rear right side airbag on the left side tonight
anyways, i'm close to getting the car to cali for the coil over conversion and just weeks before i can get out there the left rear air spring goes out completely. obviously i don't want to spend money on a new $1200 oem rear air spring knowing that i'm just going to remove it almost immediately so i checked around for aftermarket and oem replacements from all the online outlets. of course, everyone was out of their $850 replacements. so then i started looking for anything used and as many of you know it's almost always the right front and left rear that go out first so there were no left rear airbags to be had.
after careful inspection i realized that the only true factor that makes these units side dependant are the hoses and reservoir...the bag itself is pretty much universal. so i located a good used right rear air spring and removed the reservoir and it's hose but i left the small nylon air tube attatched to re-use. after following the star instructions for deflating the air spring we removed the clamp and reservoir hose from the bad air spring so that we could leave those in place. the good thing is that by not removing the reservoir from the car, you don't have to drop the subframe to remove the bag! so we unbolted the bag (1 bolt) and it popped right out. installed the new bag, reattatched the reservoir line with a new heavy duty clamp, reattatched the small nylon air line and we were done. it probably took us just over an hour of actual work.
just thought i'd throw this out there because i know many of us would like a cheap (and super easy) fix for replacing bad air springs.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
