One of new Texas mile mods (Super flow rail)
PLATINUM SPONSOR
This is one of about 7 new sample mods that I fitted on the CL55 for the mile event. This is a very versatile fuel rail with four 8AN fitting options, so you can pretty much attach any fuel lines, regulators, pressure gauges or sensors to it. The stock rail inlet is only about a 1/4" and that can not handle much flow for over 500 hp. The injector rail holes are also small and made for small sized injectors. A lot of the aftermarket injectors out there have small inlets in them as well, as they were just upsized (drilled out) form smaller 24 lb injectors.
I am having a couple changes made and get it annodized next.
Rail inlet line view. Small stock 6mm (.023) VS 8an (1/2") inlet!
Small stock injector inlet VS high flow rail inlet!
The inlet on my 76lb injectors VS the 52lb Red injector (modified 24lb injectors)
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
PLATINUM SPONSOR
The high flow fuel rail was also needed for my E85 conversion and to handle larger than average HP. 550 and up HP, need to consider these upgrades, as the high torque of these engines can not be overlooked in the power /fuel usage.
__________________
www.ultimatepd.com
www.ultimatepd.com
PLATINUM SPONSOR
Fit is all good, just need to get them anodized and alter ther mounting bracket a little more. Very easy to install too!
__________________
www.ultimatepd.com
www.ultimatepd.com
