Datalogger system - just Checking in...
Old Oct 21, 2011 | 09:52 PM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
It's been a while since I have been looking for gauges/dataloggers etc .. After searching for a while seems like the Dashdaq/Zeitronix combination is still one of the best. Threads I have found are somewhat old .. wondering if this combo is still the best set up in people's opinions?
I was about to buy the combo on Needswings.com. If anyone knows of any better systems, better places to purchase or coupons for Needswings, please let me know .. you guys usually have the most updated information and best advice on this type of stuff ... and don't lack opinions !
Thanks!
Old Oct 21, 2011 | 11:13 PM
320 dreamer's Avatar
2003 porsche 996 turbo
still the best imo and rob is top shelf. he will set you up with everything you need and can install it also
Old Oct 21, 2011 | 11:20 PM
jmb614's Avatar
E55 AMG
+1
I have the ZT2 and Dashdaq, also have a 3.5bar MAP sensor all hooked into a dashdaq. Will probably pick up a ZT3 to monitor the other bank along with an EGT probe.
I believe Bruce at TTM also sells the full setup.
Old Oct 22, 2011 | 12:41 AM
adianaty's Avatar
E55, CTS-V Wagon, Duc 1098R
I was really stuck between the Zietronix and the Innovate LM-2. Ended up getting the LM-2 full kit with case for $300 new to my door and couldn't pass it up. I'll let you know if it has any limitations but clearly the Zietronix is the best out there but costs over 2X more...
Is the car all buttoned up yet?
Ali
Last edited by adianaty; Oct 22, 2011 at 02:02 AM. Reason: Took OP's name out for anonymity.
Old Oct 22, 2011 | 10:01 AM
Bramage's Avatar
F-250
Zeitronix / Dashdaq / Rob Needswing.com
^ Agreed 100%
This was the advice I was given, and have been fully satisfied.
This will be a good thread to post up some of the data I collected while doing my set up.
Old Oct 22, 2011 | 10:16 AM
Bramage's Avatar
F-250
I got the kit with a ZT-2 and Dashdaq from Rob. Rob went out of his way to find information to help set this up. I just added a ZT-3 to get AFR on bank 2
I set up the following:
Boost - Sensor from Rob
Throttle Position Sensor - Tap into C3/21
RPM - Tap into Cam Position Sensor (C3/2) If you tap into RPM signal, you will get crazy spikes
AFR Bank 1 - ZT-2 included O2
AFR Bank 2 - ZT-3 included O2
(Note: ZT-3 does only AFR, but is much cheaper. Good alternative if that's all you want to log)
I get the following from the OBDII Connector:
Air Intake Temp
Long Temp Fuel Trim
Short Term Fuel trim
Speed
Timing
With this set up, any competent tuner can fine tune under real world conditions. It is amazing the difference you will see between a dyno and a true pull.
Here is the info for tapping into RPM / TPS (Thanks ROB at Needswing!!!)
Old Oct 22, 2011 | 10:26 AM
Bramage's Avatar
F-250
Cant beat data!
Old Oct 22, 2011 | 10:32 AM
turbo97se's Avatar
Hey Ali and others and especially Bramage in this thread - awesome info!
Thanks for the advice .. especially thanks to you Ali for your help. Between you and Shardul you guys have been awesome for my mods! I never knew your screen name on here until now .
The car is all back together and I have been driving it for a couple of days. It is running a tad rich but that is ok I have checked a couple of plugs and they are not fouled so that's good. But there is a very slight miss and it is getting lazy to start. Not sure what is going on here. I want to check all the cylinders (just been checking the random one or two. I have just bought plug wires too cos it's still running the original ones!
I was going to put on one of my Prologgers to log A/F, RPM and boost but thought, I should consider the Zeitronix and Dashdaq after reading about so many positive comments about it. Another thing about the Dashdaq is that it can work with my AEMs so I could potentially pull it out and connect to AEM. I have tried one of the Innovates a long time (first gen)ago but it was huge and not real pretty LOL.
Ali
Old Oct 22, 2011 | 10:37 AM
Bramage's Avatar
F-250
Might even be able to find a custom AMG skin for the dashdaq that looks like AMG gauges.. I dont know....
Old pic, and gauge labels have been corrected.
Old Oct 23, 2011 | 05:39 PM
jmb614's Avatar
E55 AMG
That skin looks eerily familiar, Bramage!! Big thanks to Dane, Shardul and others here on the forums for making the installation a breeze! Without their help it would have been a much more difficult installation!
Old Oct 27, 2011 | 08:41 PM
lowprofile's Avatar
E55
Good info Dane, and thanks again for the skin.
I have a couple of realted questions. Has anyone attempted tapping into the stock MAP sensor and feeding that signal to User1 or 2? From what I can gather, you can program for an additional temperature or pressure reading. What zeitronix does not state though is if they use a floating signal. We already know how tempermental the electronics are for Mercedes.
Thoughts and/or opinions welcome.
Old Mar 8, 2015 | 11:11 AM
gaiex's Avatar
'13 E500 Coupe AMG// '17 E350d // '24 E53 AMG
Old Thread, but do you know guys if with only a ZT-2, without dashdaq, with PCMSCAN or ScanXL from Palmer performance engeniering can read also aux sensors from the ZT-2?
Any one tested it?
https://palmerperformance.com/produc...lpro/index.php
(on data logging part...)
Old Mar 8, 2015 | 11:51 AM
kponti's Avatar
E63
Using that now. The problem is dataloging via Bluetooth. I would like a hardwire option.
I am considering buying this http://www.amazon.com/gp/aw/d/B001LIULX6/ref=ox_sc_saved_image_2? ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Old Mar 8, 2015 | 05:03 PM
gaiex's Avatar
I am considering buying this http://www.amazon.com/gp/aw/d/B001LI...saved_image_2? ie=UTF8&psc=1&smid=ATVPDKIKX0DER
You made it working via bluetooth or are you saying that it have some problem?
By the way, do you have a zt-2 with only o2 sensor or you have more things connected?
If zt-2 can pass data from aux sensors and TPS, EGT, etc. to ScanXL/PCMSCAN I definetly will buy one over LM-2 from innovate, if not, LM-2 makes more sense and is cheaper and can have Bosch LSU4.9
Old Mar 8, 2015 | 05:10 PM
Hulk's Avatar
A Merc
Kponti how are you making the zt2 log and live data with that Bluetooth apparatus ?
Old Mar 8, 2015 | 06:11 PM
kponti's Avatar
E63
No Zeitronics parts. I am using PLX parts altogether and dataloging via Bluetooth. SM-AFR setup with the iMFD and dataloging with the Palmer software in the above link
Old Mar 8, 2015 | 06:14 PM
Hulk's Avatar
A Merc
Oh ok that's different than zt2 with dashdaq
Old Mar 11, 2015 | 01:03 AM
10-94's Avatar
09 E63 - 03 Sonic Blue Lightning - 09 F150 4x4 Beater
What kind of issues are you running into with the Palmer setup and Bluetooth? I am thinking about picking up that setup myself
Old Mar 11, 2015 | 07:22 PM
kponti's Avatar
E63
Datalogging in graph format to send to a tuner is still a *****. The Kiwi bluetooth option isn't always reliable and I believe OBDII data is a step behind the AFRs from the SM unit. Carrying a laptop is no bueno just for datalogging. I might buy that logger and see if that works better
Very easy to install and seem pretty accurate
Old Apr 11, 2015 | 08:21 PM
gaiex's Avatar
Any one tested it?
Ok, I found it finally.
It looks it's possible and easy!
See my attached picture, ScanXL can read also the sensors from the zeitronix ZT-2.
I will get a ZT-2 unit now that I know I can datalog from external sensors and from OBD2.
Attached Thumbnails Datalogger system - just Checking in...-scanxl-pcmscan-zeitronix.jpg
Old Oct 1, 2015 | 12:32 PM
medamullet's Avatar
2011 C63 AMG
I am interested in logging from my laptop. It's much easier to manipulate the data in spreadsheets and what not. What are my options for logging? Also I have the Innovate Wideband standalone so that would be nice to be able to interface with the software as well.
