New Air intake!!!
#51
GT-ER: 100% agreed! That is why there is sometimes some room for performance improvement! But I like to see hard core numbers, not "theories". I have seen many mods that were supposed to help, but the dyno and especially the track told otherwise. This can be the result of moving the power band around out of most of the useable range, making more peak power, but lower across the average, etc.
#52
2005 E55 AMG
#53
Intakes
This intake situation , is internal combustion engine class 001 ,, the colder the air in the more horse power , I don't care how u do it and how it looks... Anything in the engine bay will not make more power /hot air ,, it may sound better and seem to respond better , but are you making more or less power .
#54
#55
I did see Hadi's intake system and it made power from what he said, but I would like real world data on the same day, at the same track or dyno, thats all.
#56
2005 E55 AMG
That is not true, look at the B5 S4 audi's intake system, it to is in the engine bay and when you add a CAI to the car is does maybe a couple HP if that. That factory system along with the E55 factory system is damn efficient, so just be adding a CAI will not always bring on more power.
I did see Hadi's intake system and it made power from what he said, but I would like real world data on the same day, at the same track or dyno, thats all.![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
#57
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
fwiw none of the aftermarket b5 s4 intakes really make any power until you get over 500whp as that seems to be when intake airflow restriction comes into play over the stock 2.7tt box... and at that point everyone is running meth to cool down the intake air anyways so without the meth the engine bay intakes on the 2.7tt's probably would result in more pulled timing without the meth
i think getting meth to work right on the E55 is really the next progression in these cars and a lot cheaper than TMIC
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
#59
E55, CTS-V Wagon, Duc 1098R
#61
#62
1 Post
05 crossfire w/SL55 drivetrain installed by Rudy Compart Intake/Needswings best et-10.76 @ 129
got mine the other day here is a pic of the intake on a friends E55 I'll post pic of mine as soon as i install it. if you can not see it go to https://mbworld.org/forums/c32-amg-c...-new-post.html
post 23 it is there/ jim
#63
PLATINUM SPONSOR
My intake is duel 3.5" tubes that merge into a larger Y pipe. The stock intake box is pretty good but once all the mods go on,, the stock boxes really start to hurt! Especially with super sized pulley`s..
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
