Harmonic Balancer install gone wrong
05 ML-500 , 03 CLK5.5 AMG has left the Garage
Well Awhile back , I put a thread in the engine parts for sale Here. for a Used 178MM Fluidampr. I had agreed with the Customer too exchange out his good used one for a new 182mm Fluidampr. Well quite some time passed . And I got a e-mail from him . all mad about the 178 he was going to send me . HIS tech!! said It was bad and he didn't screw up the install.?? And He is not paying for the upgrade. So I asked him to calm down and send it anyway. This is what I got back. See Attached pictures.
The bolt flange seated nicely with full contact Patch, The oem key way is 4 o’clock, but look at the 4:30 area at the bottom , see the metal pushed up
This is a better shot. The fit between the Crank snout & The OEM HB is about .00015. Kinda Loose by US Designed Motor & Fit. It is easy to feel the engagement ? Alignment of the key inserting to the keyway when installing. The Fluidampr is a Tighter fit .001 Instead of the .0015. . It installs not quite as easy , and you must feel for the key to keyway fit.
As you can see this install was about 10 Degrees off .< Really Bad .But, Notice that there is no Fretting of metal transfer from being a loose fit in the bore area. No metal roll up on the drive side as if it was a loose / improper torqued bolt. < Really Good!!
This is the way I install the new HBs. I set the OEM one to 37 – 38 degrees ATDC. Remove it , Mark the new one at 37 – 38 degrees ATDC. Feel for the key engagement. , Because of the tighter fit , it may not bottom out against the oil pump drive sprocket , during a hand install .So I use the old bolt & the 1 1/16” socket adapted to a 1/4” drive ratchet to bring it in the rest of the .310 , That way you feel it slide into place. Remove the old bolt install the new one , Tighten to the new Higher torque spec 180 Ft lbs & stretch 90 degrees .For real critcal installs I remove thw motr mount assu & Starter motor. I intall a flywheel lock , with the motor at 37 - 38 degrees ATDC. It is a pain in the A$$, and Time consuming, But I know it is correct.
If you also look I paint mark the 90 degree Stretch points
So At this point , we have to find a way to get paid for the replacement part that was damaged. It was not the owners or my fault , and the owners
(Master Tech) tech / installer needs to know that more attention needs to be paid too. I had this returned assy sold , for $450.00. But that is out the window LOL. Maybe you & your tech can trade out some labor for this mistake.
Good luck getting that Master Tech to own up to that one.
I've been in that finger pointing situation before.
Hope that customer finds a new Master Tech.
It's very hard to find a honest competent mechanic these days.
This Tech must of had some BIGs Guns. The tech said the pulley ran True , and no oil leaks?? Christ almighty, the barrell was out of Round. My Guess He was in a Big Hurry, and saw some easy side money. After the dealership closed for the Day.Cheers _PTEngineering
2003 E55 & 2014 GL550
This is the way I install the new HBs. I set the OEM one to 37 – 38 degrees ATDC. Remove it , Mark the new one at 37 – 38 degrees ATDC. Feel for the key engagement. , Because of the tighter fit , it may not bottom out against the oil pump drive sprocket , during a hand install .So I use the old bolt & the 1 1/16” socket adapted to a 1/4” drive ratchet to bring it in the rest of the .310 , That way you feel it slide into place. Remove the old bolt install the new one , Tighten to the new Higher torque spec 180 Ft lbs & stretch 90 degrees .For real critcal installs I remove thw motr mount assu & Starter motor. I intall a flywheel lock , with the motor at 37 - 38 degrees ATDC. It is a pain in the A$$, and Time consuming, But I no it is correct.
Fuuny thing about this one , is the Key was still intact , no damage to it. & The Crank snout, had no damage . Go Figure
