IC pump wiring question
If you power the pump with a 12 volt source at the factory source, you will be throwing 12 volts to the circuit that the ecu controls.
You could accomplish what you are trying to do with an inline diode on the stock power source, so it is possible.
Several of the guys have their pumps setup to run constantly when the key is on, which is an easy way to do it.
Think of electricity like flowing water. A diode is a one way check valve for electricity. If you put a diode in the stock circuit, electricity would only flow from the source to the pump when the ecu opened the circuit. When you flip your switch on, electicity would flow to the pump and the diode but the diode would not allow the electricity to go to the stock circuit.
Bottom line is it would be much easier to power the pump to run all the time that the engine is running. I'm a bit surprised more folks don't do this. I guess I should look at doing this myself.
Stock positive wire routes to input 1.
Switched 12v source goes to trigger 2. Single output from relay goes to + ve of pump.
To the OP, are you assuming that the ECU is controlling the pump through the hotside 12+? I have not tested it, but it could be recieving + voltage all the time and controlled via the ground side.
