Sharduls page was delete!!!
Also part II. Move to **************.com for the latest updates on Shardul and the houston crew's extravaganzas. The details usually end up here eventually. But the quickest details emerge at plantetsupercar.com
Also part III. A classic.
http://www.youtube.com/watch?v=nZMwKPmsbWE
http://www.youtube.com/watch?v=sJuL9..._order&list=UL
If I can recall you and Exotic had the same mods. The only thing that was different was that you had the Kleeman headers and he had larger headers.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
That this 170+ post thread wasn’t previously closed or deleted ought to bespeak a certain impartiality and leeway amongst MBW Staff.
Many here respect shardul for his considerable mechanical acumen, and appreciate his myriad contributions to this forum. I’m one of them.
just having some fun. Shardul is a tremendous contributor, and should be returned to service immediately. He has helped me directly more than once!
