little trick fix to help harsh s/c
Here is what Iv done for the past few months with almost 100% fix for it.
I have tried about 4 different size belts and swapped out the pullies to find a setup that puts just enough pressure on the blower without it slipping and enough to not let the belt slip.
Right now I have my car almost as smooth as stock and most of the time I cant even tell if the blower engaged and worries me that something is wrong.
I think Im running a 51.5 in belt,that helped alot but it was still there so I started messing with spacers that you can jam in between the tentioner and the line that lifts the pulley a little.
Take a small rubber object and lift your tentioner and put in in there and mess with the space until you find a sweet spot where there is no jerk and no belt slip.
You will love the way the car drives without the harsh jerk the big pulley makes.
a 2-3mm smaller tentioner pulley would also do the same trick!!!
I dont think the jerk is from the belt.I think the tentioner is putting load on the actual supercharger bearing/clutch and that little etra load is not making it spin free.
try it,it will take 2 seconds.Just find a rubber stub to jam in there.The one I have now is about 2-3mm thick.
Welcome back shardul!
