New E55 Supercharger power pulley/clutch!
Old 11-17-2011, 12:41 PM
  #101
SPONSOR
loungn14's Avatar
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Im down for one shards...
loungn14 is offline
Old 11-17-2011, 03:41 PM
  #102
abhatti55's Avatar
'19 G63 Ed 1,'18 M5, '16 G63,'12 458 , '11 E63, Brabus SL55-K8, '10 S63, '94 E500 "Wolf", '91 560SEC
Will the pulley retain the OEM Nachi bearing, or hopefully something of equivalent quality.
I know it was an important factor to use that bearing when replacing it on the stock pulley.
Thanks, about to preorder as well.
abhatti55 is offline
Old 11-17-2011, 05:28 PM
  #103
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
yes it has a german bearing of equivalent quality and speed rating
shardul is offline
Old 11-19-2011, 05:04 AM
  #104
BlackCard's Avatar
CLS55 AMG
I'm in! Shardul, we've already confirmed!
AJ
BlackCard is offline
Old 11-19-2011, 07:56 AM
  #105
Ali_E55's Avatar
C218 CLS63TT PP Edition1, W213 E63S
no intention of anything, but alot of guys were installing smaller S/C pulley here in UAE since 2009. i think it was stock pulley that was shimmed to a smaller one.
the S/C pulley they used to sell was about 5mm smaller than stock and for $1800, i don't know where they were made or manufactored.
it is easier to install and better than adding extra load on the cranck.
but i would recomend to install also S/C belt rap kit with it.
great things i am seeing that are being made for 55k since i sold mine.
Ali_E55 is offline
Old 11-21-2011, 07:54 PM
  #106
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
This is a complete new pulley assembly and bearings. Better than the factory assembly. IMO. Lighter, smaller and great bearings!
I developed a belt wrap kit and test fit it on my car before the Texas mile. Easy to install, top quality materials and bearings. Was going to dyno test on another car but have not had the chance yet. Kits are in the early production stage right now and many of the parts are completed. New belt sizes are also in and ready. Great kit and perfect amount of wrap!!!
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Exotic-metal55 is offline
Old 11-22-2011, 12:07 AM
  #107
e500slr's Avatar
2011 E63, 2013 CLS63
OFF TOPIC: Ali how's the new CLS PP? It looks incredible God I wish I could get one
e500slr is offline
Old 11-22-2011, 02:00 AM
  #108
Ali_E55's Avatar
amazing my friend, it is side by side with my 505rwhp E55k i had, called the new owner of E55 and tested it from rolling @ 60km - 220km. a true beast with the performance package. and will mod it soon i tried with an SLS and was a tad faster until my limiter hit @ 250km and he passed by. also tried wth SL65 Black series and he was ahead of me by 2 cars length untill my limiter again hit @ 250km.
https://mbworld.org/forums/cls55-amg...ck-sl65bs.html
my car is stock.
Ali_E55 is offline
Old 11-23-2011, 07:50 AM
  #109
Snogard's Avatar
I have custom 82 mm SC pulley (-8 mm from stock diameter/ equivalent to 168mm crank pulley) for nearly a year now on E55 and for 5 years on my SLK. Been there done that. Look at my signature and look at the thread "ideal pulley design" from some time ago...https://mbworld.org/forums/w211-amg/...-design-2.html
Calculation is also pretty simple;
Stock ratio: 154mm crank and 90mm SC pulley at 6500 rpm give us 154/90x6500=11.122 SC rpm (on SC INLET shaft where clutch is sitting on).
Stock crank pulley fi 154mm and custom 82mm SC pulley give us 12.207 SC rpm.
168mm crank pulley and stock 90mm SC pulley give us 12.133 SC rpm.
So my 82mm custom SC pulley is the same like 168mm crank pulley, but with MUCH LESS parasitic loses and MUCH LESS stress on the crank.
Keep in mind that internals of our SC spins even faster because of SC internal gearing.
Snogard is offline
Old 11-25-2011, 04:08 AM
  #110
mikey33's Avatar
2004 E55, 1997 E320 "Sold"
Is this the same thing as the 172mm or 180mm pulley that most sites sell like eurocharged and asp?
mikey33 is offline
Old 11-25-2011, 06:35 AM
  #111
shardul's Avatar
no one that i know sells a smaller SC pulley
shardul is offline
Old 11-25-2011, 09:10 AM
  #112
e500slr's Avatar
my car is stock.
The more I hear about it and see it the more I want one
e500slr is offline
Old 11-25-2011, 09:48 AM
  #113
novae500's Avatar
W211
count me in as well!!
novae500 is offline
Old 11-25-2011, 04:36 PM
  #114
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Originally Posted by shardul
you are spot on!
Just keep adding lightness.
AgSilver is offline
Old 11-28-2011, 04:40 PM
  #115
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
pencil me in too as my s/c pulley is starting to throw out some muck so i think the bearing assembly is going south...
if i ran just this s/c pulley looks like it would be like a 168mm crank pulley equivilant so would you guys be teaming up with E/C on this for tunes? i assume i could just get a 168MM tune with running just the s/c pulley and call it a day ?
gaspam is offline
Old 11-28-2011, 04:59 PM
  #116
DVC
DVC's Avatar
'06 E55 AMG
Please count me in and PM with pricing info.
DVC is offline
Old 11-28-2011, 10:02 PM
  #117
keith954's Avatar
cls55
Can you give me the pricing info also, and an estimated month this will be ready.
keith954 is offline
Old 11-28-2011, 11:06 PM
  #118
mikey33's Avatar
I might be in if I knew what the heck this was?? Is this the "typical" pulley that you usually buy with a tune or something else?
mikey33 is offline
Old 11-28-2011, 11:28 PM
  #119
Denroll's Avatar
'06 E55
It's something else. The "typical" pulley is the lower one that is on the crank. That's why a larger one is better. This one is up top on the supercharger itself, which is why a smaller one will make the s/c spin faster. The lower weight is also a good thing. Combine the two for winning.
Denroll is offline
Old 11-29-2011, 06:00 AM
  #120
mikey33's Avatar
Thanks for the explanation Is there a reason why this is only being developed now after so many years?
mikey33 is offline
Old 11-30-2011, 06:01 PM
  #121
PLATINUM SPONSOR
2003 CL55
Yes, I used some really good engineering software to pre-test some design ideas and make it worth the effort. Again, this is a complete new CNC made and performance improved SC pulley. I cant wait to feel the REVS on my new engine build!
Here is a hot off the press sample picture. One really cool feature is the over 30% in weight reduction !! Stock SC puley is 3.5 lbs and this is only 2.5 lbs!! This is huge for getting up to power quicker and lowering streess on your SC components! This super SC pulley will put you equall to a 170mm pulley. (stock is 155).
__________________
www.ultimatepd.com
Old 11-30-2011, 06:04 PM
  #122
gaspam's Avatar
PM me pricing when they are ready as i need a new SC pulley soon
gaspam is offline
Old 11-30-2011, 06:09 PM
  #123
DVC
DVC's Avatar
'06 E55 AMG
I can't wait until they ship. Any pics of the belt-wrap kit boss?
DVC is offline
Old 11-30-2011, 06:10 PM
  #124
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
What is the pricing on these?
AKnight55 is offline
Old 11-30-2011, 06:35 PM
  #125
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
And if my car doesn't have any crank pulley upgrade, can i still use this SC pulley ?
CharlyE500 is offline
Quick Reply: New E55 Supercharger power pulley/clutch!
