New E55 Supercharger power pulley/clutch!
#152
might come in handy for those lucky enough to have one! also if we could figure out how to keep the ecu from bleeding boost at higher rpms i don't think we'd need any of these super high boost options.
__________________![](http://www.oxilab.info/huang4.jpg)
![](http://www.oxilab.info/huang3.jpg)
__________________
![](http://www.oxilab.info/3.jpg)
#154
s/c pulley
Sounds really Good , can't wait to see dyno #'s ... what would this do for a 168mm crank pulley ,,,, I'm in if it works out, more boost , more power , less engine stress ....
#157
to everyone involved with this project.............
much respect!!!!!! you guys are real 55 legends!!
is this going to be sold as a package??
#159
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
#160
PLATINUM SPONSOR
Yes, it would put you n the range of a 180mm pulley, that revs quicker, boost up quicker and less stress.
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
#161
Currenly, with a either a 180 or 190 pulley, my boost goes from vaccum
to full boost in 0.49 seconds. The time it takes the TPS to go from 0-100 is 0.23 seconds, so I think any increase there is irrelevant. Boost is already instant.
All other factors are valid
#162
When is this pulley going to be available? My stock clutch assembly is toast and I want it replaced as soon as possible!
#163
I look forward to the data, but boosting faster?
All other factors are valid![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
#164
PLATINUM SPONSOR
__________________
www.ultimatepd.com
www.ultimatepd.com
#165
PLATINUM SPONSOR
One test car has over 3000 BIG smile on his face miles now!
A ton of road kills to go with it. hehe
__________________
www.ultimatepd.com
www.ultimatepd.com
#173
