Way to check IAT in car?
I searched for about an hour and didn't find anything that would show how to check the IAT in car (but I thought I saw a way to do this while searching something else). Is there a mode/way to do this without using any external datalogger/laptop?
Thanks!
Thanks!
obd 2 scanner.. can get them at autozone for around $100 or so
cheap way is to get an obd2 bluetooth adapter off ebay and use a droid cell with a obd2 scan app.
Most are free and only like 5 bucks if you want the full versions.
Thats how I do it and it will cost you about 35 bucks with the full torque app
Cool! Thanks guys! I have a Droid..
Are there any blue tooth adapters you guys suggest? There are alot of different ones out there.
There was also a guy who wired his outside temp gauge to ready IATs, so he could read them on his dash... Might also be something to look into if your only concerned with IATs
Look into Dash Dyno.
Plugs into the OBDII port and gives you live data of your IAT, AFR, etc.
Borrowed one from my buddy a while back and its a cool little gadget.
Here is a link.
http://www.dashdyno.net/
Here is a link.
E55 AMG W211 - sold, CLS 500 C219, E63S AMG W212
Can somebody tell me which obdII bluethooth adapter i can connect with my iphone 4?
Is there an app which can measure the acceleration (60-130) and check the iat?
Will this one work?: http://www.ebay.com/itm/Vgate-ELM327...item45fc0a4d9b
I didnt specifically see my vehicle on the list and that is why I am asking.
well i got the ELM 327 working with my Iphone. Here's how:
1. first of all your phone needs to be jailbroken
2. go into Cydia and download roqyBT4, this will give u full bluetooth functionality
3. download roqyOBD add-on as well
4. configure roqyBT4, you need to purchase a license, which costs $6. then you can connect to the OBD sensor, it creates a new address, which is 127.0.0.0, port 35000
5. go into DashComand. add a device with a custom IP to match the one above.
6. all done, it will connect now.
btw, which parameters are you guys datalogging with dashcommand? i can't seem to find the boost display. i've got speed, rpm, IAT and timing so far
