Kleemann Header install. Difficulty?
Rating: Thread Rating: 2 votes, 5.00 average.
Old 12-07-2011, 09:07 PM
tbal's Avatar
Haters crazy
Arrow Kleemann Header install. Difficulty?
Has anyone installed any shorty style or Kleemanns? Difficult, or is it really tight fit? You can say I have Moderate mechanic skills... Considering doing this with a buddy. OR should I not bother and have it don.e at an indy shop?
Thoughts? Saw BrainS DIY and looks pretty straight forward, but i dunno
Shardul? lol
Old 12-07-2011, 10:05 PM
GT-ER's Avatar
2005 E55 AMG
What's the hardest thing you've done in a vehicle? I'll let you know how the header install compares...lol.
Old 12-07-2011, 10:11 PM
Benz-O-Rama's Avatar
Simple, but your back will be a bit sore from leaning over the engine for a few hours.
Remove coil packs, use an open ended wrench as a lever, to pop the plug boots off. Go ahead and use this opportunity to change your plugs. Use a little dielectric grease inside the plug boots when you reinstall.
I've done shorty headers twice in a driveway.
Old 12-07-2011, 10:20 PM
AWOL's Avatar
e55
I did VRP shorties in about 6 hours. Its not particularly hard, its just time consuming. You'll likely get bloody knuckles.
The hardest part is putting on the gaskets if the bolts back all the way out with the nut. That shiz made me mad.
Old 12-07-2011, 10:29 PM
JoshM813's Avatar
2005 E55 AMG
Ive been contemplating this on my ramps...but not sure if id have the room...i do want to try it but I dont want to take 10hrs either...
Old 12-07-2011, 10:33 PM
whipplem104's Avatar
1990 300ce supercharged and intercooled
Biggest problem if you have moderate mechanical ability is that you have to cut the cats out and weld up the pipes. The kleemann stuff does not really line up with the stock pipes either.
I always suggest removing the stock pipes completely and making new and keeping the stock ones for if you want to put it back or sell them.
Old 12-07-2011, 10:41 PM
AWOL's Avatar
e55
You'd have enough room on ramps.
Old 12-07-2011, 10:56 PM
JoshM813's Avatar
2005 E55 AMG
So I may attempt this...i had taken my 335 in too many times to get stuff installed id rather have the satisfaction on doing it myself now with the 55
Old 12-07-2011, 11:02 PM
tbal's Avatar
Haters crazy
Planning on keeping my cats...
Old 12-07-2011, 11:06 PM
tbal's Avatar
Haters crazy
Things I've done on my car/other 55k's...
SC clutch
IC pump
HE
split cooling and front mount tank
e63 bumper install
pulley installs
gaskets on valve covers
cps sensor
spark plugs
You tell me
Old 12-07-2011, 11:21 PM
AWOL's Avatar
e55
Then youre capable.
Bring bandaids
Old 12-07-2011, 11:49 PM
nicco's Avatar
E55 AMG
If you keep your primary cats in is there any welding involved??
Old 12-08-2011, 12:27 AM
ssonss1's Avatar
Flying Spur
Originally Posted by AWOL
Then youre capable.
Bring bandaids
Ouch! i'm sure tbal is ready for that, he sent me a pic last time with blood all over his white bumper
Old 12-08-2011, 12:57 AM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
The kleemanns come with a down pipe that deletes the primary.. Pretty sure it wont bolt up to the primary (have to use the down pipe).. Welding is necessary with these shorties
Old 12-08-2011, 01:02 AM
kustom2k1's Avatar
03SL55
What AK said, I had a set installed by an indie MB shop, cost was 500 for the install.
Old 12-08-2011, 01:36 AM
tbal's Avatar
Haters crazy
Lol... im all in for sweat n blood...
Damn another dilemma, to delete cats or not... I'm just worried about emissions...
Old 12-08-2011, 01:40 AM
AKnight55's Avatar
Pretty sure you could go with some aftermarket cats, but not the stock cats with these.
Old 12-08-2011, 07:49 AM
GT-ER's Avatar
2005 E55 AMG
SC clutch
IC pump
HE
e63 bumper install
pulley installs
cps sensor
spark plugs
You tell me
You are qualified then... It's really not that bad. I'm half way through a C55 header install and it's worse than the E55 install...yet still not HORRIBLE.
My previous G35 was HORRIBLE.
Old 12-08-2011, 07:50 AM
saleen01's Avatar
2004 E55
you cant keep the stock cats, this is not a "shorty header" you need the down pipes and the cats will be deleted on the stock pipes, you'll need to cut the factory pipe and weld new flanges, mechanically its just time consuming, but if you haven't welded exhaust before, i'd leave it to pro.
Old 12-08-2011, 08:22 AM
novae500's Avatar
W211
With the prior work you have done, you can DIY. However talking to Cory regarding emissions/readiness, you can send the ECU to him and he programs a file that is separate from the tuned portion of the ECU to think that you have both cats so the o2s read correctly. He also said you can put new primary cats in, but still may have to weld due to the alignment of stock exhaust.
Labor quotes i have received is 5-6hrs. Komp55 has a good DIY on his evosport header write up. Only difference would be the welding of the downpipes/aftermarket cats if you go that route.
Old 12-08-2011, 09:38 AM
pullejo's Avatar
'12 E63, E55(sold), C32 (sold), '65 Skylark GS 445 convertible, '12 ML350
I'm running no cats....just passed emissions last month with flying colors.
But...they don't do a visual here.
Old 12-08-2011, 09:42 AM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Think that is impossible. First set of cats up top will be gone for sure.
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
with the Kleeman header install there will be some cutting involved since the primary cats are eliminated.
Old 12-08-2011, 09:43 AM
Roverron's Avatar
ML63
In some states they will allow 1 to 2 readiness codes PA will allow you 1 readiness code.
Old 12-08-2011, 01:43 PM
novae500's Avatar
W211
VA is the same way. So options are:
-Send to Cory to trick the ECu with updated file
-get aftermarket cats as primaries
-talk to Bruce TTM, he can help you out with readiness...
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: Kleemann Header install. Difficulty?
