Tested the best crank pulley and it has adjustable boost features!
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
if you all were only in HTX you would be able to see the crazy stuff we do. Thank God i am not married, if I was I would be divorced by now. Alll my free time is spent with doing car stuff.
That's great news! Thanks again for all the recent exciting stuff you've been posting. It seems like between the smaller S/C pulley and these easily-swapped crank pulley setups almost anyone out there can fine-tune their car for the type of behavior they want.
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
For an incremental cost (of a new outer crank ring) someone who has just upgraded their cooling can go to a larger pulley.... or someone who has overdone it and heat-soaked their motor can trade-down with another member to get the IATs back in check. You're right... the horsetrading of parts between members will be great. IMHO is the essence of what an enthusiast message board should be about.
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
-G
PLATINUM SPONSOR
That's great news! Thanks again for all the recent exciting stuff you've been posting. It seems like between the smaller S/C pulley and these easily-swapped crank pulley setups almost anyone out there can fine-tune their car for the type of behavior they want. ![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
For an incremental cost (of a new outer crank ring) someone who has just upgraded their cooling can go to a larger pulley.... or someone who has overdone it and heat-soaked their motor can trade-down with another member to get the IATs back in check. You're right... the horsetrading of parts between members will be great. IMHO is the essence of what an enthusiast message board should be about.![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
-G
-G
BTW, my wife loves cars and racing, so all is good for us to keep having fun!
Here is the outer boost ring hub picture. This hub slids into the inner hub VIA perfect machine fit. As you can see, virtually no load on the bolts, thus the 100 times overkill load they offer.
![](http://i991.photobucket.com/albums/af31/Vitabc/2011-12-13112946.jpg)
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
2005 E55 AMG
Thanks! Written very well.
Feel good yet? ?
Looks good man.
I have the opposite opinion about the inner ring. You need a way to center up the ring independent of the bolts to keep it true and prevent the aluminum ring from walking around under the bolts. I don't know how much HP the s/c consumes but I would guess 60+ to turn that sucker at max rpm. That is a lot of drag.
#34
A cog belt on a clutch-type supercharger!! Reminds me of the MadMax movie..... 'cept of course the clutch on Max' must have been on the crank pulley cause the belt didn't spin at all until he "activated" the blower!!!
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
-G
#35
PLATINUM SPONSOR
This is a totally new CNC hub, balanced, and interchangeable boost ring. Kit came with hub, boost ring , belt and new AMG crank bolt.
I ran the crap out of mine, raced it, put 615 hp and 720 ft lbs of torque through it for several months! Worked perfect, belts are great and smoother than stock. As mentioned, 7 companies were involved in this product, as the tooling, molds and engineering are very high. Maybe one reaon our options have been limited until now.. One of my hobbies,, is I do business/mfg consulting, so I know a lot of people around the world to get things done. I want great parts on my car, so I am always looking for something better and of high quality.
A lot of companies are more willing to invest in making aftermarket parts for us now, but couple years ago, the laughed everytime I asked about getting something for our cars. They are seeing the AMG market value now.
__________________
www.ultimatepd.com
www.ultimatepd.com
#38
PLATINUM SPONSOR
The answer is NO I did not put anything on Ebay but maybe the company I got my new pulley kits from did? I have my kit and two 195mm kits in my posession only.
__________________
www.ultimatepd.com
www.ultimatepd.com
#39
Brooke, you may have posted it already, but is this any lighter than a welded asp pulley with stock hub? Did you publish pricing on here yet for it?
Oh, and, you are da man mang
You are taking the M113K to a level only the GODS could be proud of.
#40
Michelin and all the other tire manufacturers are sending "thank you" letters to Brooke as we speak....
Better go add a few to of those companies to my stock portfolio now. I forsee record profits in the coming year!
-G
#41
Received 1,065 Likes
E55, GLS450, GL63, GLE350
No, it was a one off custom built anodized aluminum unit by ASP similar to the one you are running. It bolted to the stock harmonic balancer and the end had the same type screws for the interchangeable pulley sizes. Yours is nicer because it has a custom built harmonic balancer.
#42
PLATINUM SPONSOR
The main steel balancing hub is two parts, just like the factory but much stronger, as it is all machined solid steel and not cast. The two hubs are put into a special mold that holds them to exact tolerances and then the vibration durameter material is injected between the two parts. Just like a factory balancer but this product uses stronger interlocking teeth design and better bonding methods. It is a slow process, as the part has to be injected, then go through a set cool down time before balancer can be removed.
I would not want a pulley on my crankshaft that does not have this rubber injected type of dampening design on it like the factory uses. Most auto MFG`s use this method of harmonic balancing and it is a well proven and effective design.
__________________
www.ultimatepd.com
www.ultimatepd.com
#43
PLATINUM SPONSOR
Here is my 195mm boost pulley on a UPS supplied scale. As you can see, right at the factory weight and that mean you hold the same harmonic balancing weight the factory desinged for the engine. The larger aluminum boost ring is light, so it does not add extra rotational inertia , when you go larger in ring size.
![](http://i991.photobucket.com/albums/af31/Vitabc/2011-11-13095548.jpg)
__________________
www.ultimatepd.com
www.ultimatepd.com
#45
2017 991.2 Turbo PDK 2017 C63S Coupe Ceramic Brakes 2015 CLS63S AMG Full House
So hopefully the new year brings some acid test 55 results, with magnificent power.
#46
PLATINUM SPONSOR
I have some pictures of the rear of the hub as well , so you can see the CNC machining. Also was sent a hub sawed in half, to show how the rubber dampening material is injected and fused in the hub. Anyone want to see?
__________________
www.ultimatepd.com
www.ultimatepd.com
#48
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
That is funny. I have 5 sets or partial sets for my car right now.. lol Can't wait to start burning mine off again.
#49
PLATINUM SPONSOR
Ok, here is a picture of the RAW solid hub, that the boost ring bolts too. I will post the hub that the MFG cut and half and sent to me next.
AGsilver, thanks!! I think a lot of people forget or not clear on the importance of maintaining the balancing weight of our engine, that the factory designed and balanced the internals to.
![](http://i991.photobucket.com/albums/af31/Vitabc/2011-12-19201342.jpg)
__________________
www.ultimatepd.com
www.ultimatepd.com
#50
