Driver's Side Valve Cover is Leaking a Bit - How Much to Fix?
Old Dec 21, 2011 | 07:20 PM
alextaylor29's Avatar
2004 E55 AMG
Guys,
After using the search feature (See I use search!) I hear this is a pretty common issue with E-Series and is generally covered under warranty. Just curious how much does this type of repair cost if done by the dealer?
Thanks!
Alex
Old Dec 21, 2011 | 07:25 PM
AMG_RL's Avatar
E55 AMG, 72' Toyota Carina, 63' Ford F100, 72' Mercedes 250c, 15' Harley Davidson Softail
not sure about the dealer but I did it myself for $17. took about 40min per side.
Old Dec 21, 2011 | 07:26 PM
2004 E55 AMG
Thanks!
Old Dec 21, 2011 | 08:53 PM
novae500's Avatar
W211
Under warranty it was $500 for both sides at dealer
Old Dec 21, 2011 | 08:57 PM
Helli217's Avatar
05 E55
This. I just ordered 2 new ones for 32 bucks. DIY is easy on wallet.
Old Dec 21, 2011 | 09:43 PM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
My dealer charged me $60 under the table.
Old Dec 21, 2011 | 10:10 PM
skratch77's Avatar
2005 E55
you sure they didnt just wipe the oil off the valve covers with a rag and take your 60 bucks?
Old Dec 21, 2011 | 10:22 PM
emoving's Avatar
Nope, my AMG mech. actually comes to the house to perform light work for me on the side!
Old Dec 21, 2011 | 10:24 PM
skratch77's Avatar
2005 E55
Gotcha I was going to say no way they would do that at the stealership.Its an *** raping everytime the car goes in there.
Old Dec 21, 2011 | 10:44 PM
WHTEVO's Avatar
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
just do it yourself, it's not very difficult to do IMO.
Aaron
Old Dec 21, 2011 | 11:13 PM
2004 E55 AMG
Thanks guys for the help as always. For a DYI, should I replace both the gasgets and sealant and where should I buy these?
Thanks as always.
Alex
Old Dec 22, 2011 | 02:04 AM
berti_00's Avatar
2016 Cls63s AMG
Do you guys use any high heat silicone when doing, and is there specific tourq for the bolts or just enough to that they are tight...
Someone should make a DIY for it... :-)
Old Dec 22, 2011 | 02:13 AM
.trunzx's Avatar
2003 SL55, 1978 280SL, 2007 ML63
https://mbworld.org/forums/w211-amg/...ml#post3339541
Old Dec 22, 2011 | 03:48 AM
DcoryHelisle's Avatar
bmw
Old Dec 22, 2011 | 07:10 AM
slownrusty's Avatar
'06 E55 K2
The gaskets go on dry (same as when the engine is assembled brand new) and the torque is very low in the 8-10ft.lbs range. The Torque sequence is very specific and you have start at the center and work your way out to the edges in a criss-cross pattern. Silicone \ Permatex \ RTV is only required for the top covers for the PCV breathers that are bolted to the valve covers.
Old Dec 22, 2011 | 08:12 AM
berti_00's Avatar
2016 Cls63s AMG
that is awsome work...
