Electronic shift kit
Old Feb 2, 2012 | 08:59 PM
Shifter's Avatar
E55, SL63, ML550
Originally Posted by isellbenz
Say it works... the tranny mount couldn't hold up to chirping 3rd. Just sayin'.
And we may not be able to chirp 3rd, I was just using that as an example from what the LX cars do with a similar type system. I'm sure they have different gear ratios than we do.
Old Feb 3, 2012 | 12:10 AM
KLR CLS's Avatar
CLS63 PP
Good thing I have an SRT8 3.06 diff gear to install shortly!
Old Feb 11, 2012 | 11:23 PM
Shifter's Avatar
E55, SL63, ML550
Teaser vid
http://youtu.be/ux0jdR4A9M8
Old Feb 12, 2012 | 08:03 AM
lowprofile's Avatar
E55
NICE!
Standing by for the next update.
Old Feb 12, 2012 | 08:53 AM
Hotrod-Realtor's Avatar
CTS-V 2013 Wagon
You have been working hard on this for awhile now and it looks like finally seeing some fruit. To me, this is pretty exciting especially if it will allow a higher number gear set to be installed in the differential and taught to play nice.
Thanks for posting and spending time on the updates.
Warren
Old Feb 12, 2012 | 10:19 AM
400RWHP's Avatar
2006 CL600
Yeah very nice and thanks for pursuing this for the whole community. There is major room for improvement in this area on our cars and just that teaser video alone is enough to see what 'could' be.
Subscribed.
Old Feb 12, 2012 | 01:34 PM
  #32
KLR CLS's Avatar
CLS63 PP
Great work brother. I knew you would get it done! One thing I think would be worth talking to the guy from ZA about would be throtttle matched downshifts. Seems like with this living on the correct CAN lines, we should be able to send the bits necessary to have the throttle blipped on downshifts. I think that would complete the package. The great thing about this vs a Valvebody mod, is the upshifts and downshifts are independant and you can fully control depending on your tastes.
Old Feb 12, 2012 | 02:27 PM
  #33
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
getting interesting! i wonder if will this be compatible for all years since the can bus was changed?
Old Feb 12, 2012 | 06:32 PM
  #34
Shifter's Avatar
E55, SL63, ML550
Could you elaborate more on which years you are refering to?
Old Feb 12, 2012 | 06:47 PM
  #35
chiromikey's Avatar
it's been a long time since i was really into this stuff but the can bus was changed at end of '03 or '04.
Old Feb 12, 2012 | 07:52 PM
  #36
Shifter's Avatar
E55, SL63, ML550
Which can bus do you mean? I dont remember that, I"ll have to go back into my books and research.
Old Feb 12, 2012 | 08:55 PM
  #37
chiromikey's Avatar
sorry, it's been far too long since i was really into modding my e so you'll probably have to tell me after you check into it!
Old Mar 7, 2012 | 09:09 PM
  #38
Shifter's Avatar
E55, SL63, ML550
bump-- its coming along.
http://www.youtube.com/watch?v=LcQ1U...hiKgcNudlkg%3D
Old Mar 7, 2012 | 09:28 PM
  #39
GregMB's Avatar
Cool!
So is that your car being used as the test mule?
-G
Old Mar 7, 2012 | 10:46 PM
  #40
Shifter's Avatar
E55, SL63, ML550
Yup that's mine.
Old Mar 7, 2012 | 11:19 PM
  #41
CTS-V 2013 Wagon
Wow, it really hits second hard. Me likey.
Old Mar 7, 2012 | 11:39 PM
  #42
chiromikey's Avatar
any release date estimates?
Old Mar 7, 2012 | 11:43 PM
  #43
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
Dang my car with a modded valve body and tcu tune doesn't do that lol. I thought it was gonna chirp 2nd after I got the valve body done but no dice. I am thinking that could get a little annoying though since it seemed to be chirping 2nd still when you weren't even doing a wide open pull.
Old Mar 8, 2012 | 12:10 AM
  #44
400RWHP's Avatar
2006 CL600
That's awesome on WOT! I am a little concerned though in the video I saw a few part throttle accels and it is even breaking the tires loose at mid tach. Are there varying degrees of the shift engagement they can program? There are times where I want my beast to be a Mercedes and be comfy and quiet (old fart).
Regards
Old Mar 8, 2012 | 12:29 AM
  #45
KLR CLS's Avatar
CLS63 PP
Ok enough c.ock teasing...get me one already!
Old Mar 8, 2012 | 12:49 AM
  #46
kustom2k1's Avatar
03SL55
**** man that thing RIPS second gear! How long before we can have some of that?
Old Mar 8, 2012 | 07:13 AM
  #47
GT-ER's Avatar
2005 E55 AMG
While this is awesome, I'd be more afraid of breaking axles, engine mounts and tranny parts than what I'm going to gain with this. After the EC update, my tranny shifts pretty quick although it doesn't bark the tires obviously, the bog between shifts is barely noticeable ( although still there ). How much quicker do you think the car would be with this and how much damage do you think this will cause in the long run?
I'll tell you what though, I'd take one just because it opens up more options...lol.
Old Mar 8, 2012 | 09:40 AM
  #48
stockC43's Avatar
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
Looks good It would be great though if it was on a switch or used the factory s/c/m switch to switch from a "normal" shift to a "fun" shift though. My car has a built trans and valve body and unsuspecting riders some times ask whats wrong with my transmission. Its hard to explain that my Mercedes has a race trans
Old Mar 8, 2012 | 10:10 AM
  #49
e55amgrocket's Avatar
Dirt Scooters
i'm in for one.
Old Mar 8, 2012 | 12:32 PM
  #50
Shifter's Avatar
E55, SL63, ML550
Thanks- advise taken I think you guys will be happy when its done. To address some concerns, it will probably have different modes you can preset and select for different levels of firmness. ie, wife setting, cruiser setting and pissed off setting. Also you will be able to tailor it for each gear change. ie, maybe you want 1-2 100%, but 2-3 80% etc also throttle reactive.
