second heat exchanger pic
Old Jan 8, 2012 | 10:40 PM
skratch77's Avatar
2005 E55
Originally Posted by tbal
Incorrect.
Check one of my old threads, I did datalogging...
My pump wired to run all the time, with a bigger HE , and a small bmw res tank with split cooling did wonders. Later added a 1.5gallon front mount tank, which made even more difference.
lol you just said exactly what I mean.When you spilt the cooling you need to add more volume to make up for the less water that is going threw the blower.
Im not suprised one bit your temps droped with a 1.5 gallon tank.
try spilting the system and running a pump all the time without adding more volume and see how that goes for ya.
Old Jan 8, 2012 | 10:50 PM
tbal's Avatar
Haters crazy
That could be true. The small bmw tank does no good.
If it works for you A, rock it! I'm suprised though with your setup you didnt do a rear mount tank?
Old Jan 8, 2012 | 10:54 PM
skratch77's Avatar
2005 E55
nooo I got a 7 series res and its about 3x bigger than the regular one people use on here.
Old Jan 8, 2012 | 11:35 PM
tbal's Avatar
Haters crazy
Ohhhhhhhhhhh! lol
Old Jan 9, 2012 | 07:48 AM
GT-ER's Avatar
2005 E55 AMG
How does the volume go down by splitting the system? It's not like the water in the coolant reservoir counts as part of your intercooler system since it doesn't circulate. I any case, splitting the system will add volume even if it's just by using a bmw reservoir.
Old Jan 9, 2012 | 08:22 AM
AK-AMG's Avatar
E55 AMG
Where are you mounting the Res?
Old Jan 9, 2012 | 09:15 AM
  #32
TheOtherDodge's Avatar
2005 E55 AMG
That is what I was thinking...
Old Jan 9, 2012 | 09:20 AM
  #33
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
the BMW resoevior people use is just a filling point. It has only one hose coming out of it, fluid does not circulate through it.
Old Jan 9, 2012 | 10:09 AM
  #34
GT-ER's Avatar
2005 E55 AMG
I thought they used two hoses...
regardless, then splitting or no splitting...the volume should be the same because the oem reservoir is also just a filling point.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
